very little traction control
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by magnumrtawd, Dec 25, 2014.
  1. magnumrtawd
    magnumrtawd Member
    305
    71
    Toledo,Ohio
    My 2010 III, not 3 or Three since it is a 2010, will break loose the tires when wet with moderate acceleration. If i floor it it will alternate spinning right to left until I back off the throttle. I"m not really complaining since I had an 08 that would not spin a tire and could not be driven in snow. Just wondering if this is normal on a 2010.
    I turned right with moderate acceleration on wet pavement today and the tires broke loose and the car was headed for the curb. Oh the traction control light does come on when this happens but, no brake application or engine speed reduction!
  2. fuzzy1
    10,254
    This is likely more a tire issue than a car issue. What tires do you have, and how many miles on them?
    I was happy with my 2010's OEM tires' winter traction only the first winter, they had degraded significantly by the second. Rain traction was probably good for two years (I kept that car 3 years). The later 2012's tires are following the same pattern, and are now breaking traction in rain with noticeable frequency. But this is really no different than the original A/S tires on previous cars too.
    My 'real winter' travel in seriously foul weather is in a different vehicle with true winter tires.
    #2 fuzzy1, Dec 25, 2014
  3. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    OP, why are you flooring the accelerator in wet conditions? ;)
    Perhaps you need to be in ECO mode to tame that Pb foot. :D ;)
    dbcassidy likes this.
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    723
    284
    Maine
    Our town is located in a low-laying around, our road follows along a river bank. We often get fog off the river. As the ground freezes, fog will settle on the pavement and from a layer of ice. this is locally known as 'black ice'. Because the pavement looks clean, but it is slicker than an ice-rink.
    We get black ice in the fall and spring, until a good layer of snow and sand are put on top of it, it can be fairly hazardous.
    In this area, we need winter tires with studs. Also studs are needed for when we are driving across rivers or ponds.
    The problem that you describe, sounds to me like you need to look at your tires.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    If your state still allows studs, it is one of only a very few.
    People tend to not take them off the car when they should and the studs tend to chew up the roads........VERY QUICKLY.
    Also if they run them WAY longer than they should, worn tires throwing out steel studs is pretty much like a gun shot.
  6. ForestBeekeeper
    723
    284
    Maine
    Hot sun evaporates tar faster in the summer, than studded tires do in the winter.
  7. Easy Rider 2
    1,584
    257
    Ocala, FL
    That's a pretty funny misconception.
    Hot tar does not "evaporate", it moves around and sticks to things.
    How about concrete. Do you think that the summer sun makes that "evaporate" faster than steel studs grinding against it ??
  8. magnumrtawd
    magnumrtawd Member
    305
    71
    Toledo,Ohio
    The tires are Sumic M/S Not LRR but were excellent in last years constant snow and only have 3K on them. ( They only cost 35$ and I averaged 48 to 50 MPG last summer.) More to the point. I didn't think Pri should allow spinning tires freely without traction control kicking in! As I said in my original post, My 08 wouldn't spin a tire with out traction control kicking in! Let alone letting me light them up !
    Full acceleration in power mode was just a test !
  9. fuzzy1
    10,254
    but I don't recall anyone reporting any Prii allowing freely spinning tires. The Gen3 videos posted so far show 'chatter' as the tires repeatedly break loose and are caught and held back by the traction control. The drivers whose winter style requires some spin still complain about not getting that spin.
  10. magnumrtawd
    magnumrtawd Member
    305
    71
    Toledo,Ohio
    Kind of my point. I'm the only one I've seen having this happen.
  11. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Mine would let it spin for a 1/2 second, cut back some, spin it some, and cut it back, and on and on, assuming my foot keeps flooring the pedal, and the traction is still limited.
    This is more noticeable as now I am approaching 50K with my OE tires down to 3-4/32nd of tread depth left.
    I thought traction control allows the most acceleration possible, given the conditions.
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Don't think I know of any car 4WD, AWD, RWD, or FWD that don't spin the tires when you floor it on wet, dry, icy, or dirt surfaces. In other words, ESC doesn't work miracles. It has to sense slip before it activates.
  13. Tideland Prius
    16,195
    These spun continuously. They were brand new Nokian Hakkapeliita R. Turning and gunning is an easy way to spin tyres on a wet surface. The 3rd gen's Prius TRAC was revised to allow some wheel spin because the Gen 2 (as you stated) doesn't allow any spin at all.
  14. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    This is how mine feels like, never got out to look. The TRAC system pulses the power, it seems.
    This is one how the GEN II failed.
  15. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    With the silver Gen 3 whats the issue? It got up the hill using traction control… It wasn't overbearing and got the car where it needed to go….
    The Gen 2, Yeah it got stuck but come on that driveway was pure black ice… Its a no win either way…
    But alas did it not get up to the garage??
  16. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    A little misconception here. AFAIK Traction control doesn't use the brakes, it just cuts the throttle. VSC uses individual brakes to control direction of travel. In other words you don't have electronic LSD.
    Sounds like you have "cheap tyres", and they are acting like they are cheap. ;)
    And yes, as others have posted, the GIII will allow -some- wheel spin. But even it won't allow full spin, there is some control of it.
    Also, yes, contrary to what certain magazine wags claim, the Prius IS NOT "gutless". It produces a lot of torque off the line. Wheels will spin if the right foot is heavy.
    robertmaria likes this.
  17. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Does use brakes. Is de facto electronic LSD.
  18. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Not true. All traction control systems use brakes to manage the spin. Some additionally reduce the power, but not all.
