Very Low Gas Mileage .... Why?
Discussion in 'Gen 2 Prius Fuel Economy' started by bdbutton, Jul 26, 2010.
  1. bdbutton
    bdbutton New Member
    Folsom, CA
    I have had my 2008 Prius for a little over a year. It had 12,000 miles on it when I purchased it. I was getting approximately 38 MPG on average. I changed tires a few months and the mileage dropped down to 35 MPG. I still thought this was good gas mileage. Then I spoke with someone that said they were getting close to 50 MPG. I had the car checked out last week by the Toyota dealer and they told me there was nothing wrong with it. The tires are properly inflated, etc. Since I picked up the car from the dealer my mileage has dropped to 30 MPG. Can anyone tell me why I'm getting such poor gas mileage? I live in California and travel mostly short distances. Any suggestions would be greatly appreciated. I'm so discouraged.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Please answer the questions at http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html.
    Please definitely elaborate on the trip length in terms of time, distance speed, and terrain. I recall some areas around Folsom are quite hilly. Short trips will kill your mileage, esp. in the city.
    Please definitely indicate what tires you changed to (make, model, size). It's very possible you've also changed to higher rolling resistance that will hurt your economy. Even if you switched to the same make and model, there will be some initial drop due to Tire Tech Information - Tire Rolling Resistance Part 3: Changes to Expect When Switching from Worn-Out to New Tires. Also define "properly inflated".
    ConsumerReports.org - Most fuel-efficient cars is what Consumer Reports got in their testing for your generation of Prius.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I'd be curious to know what your daily commute consists of. You should be able to maintain a 45-50mpg average without much effort in the Folsom area unless you are making very short trips and using the HV battery too much. :)
    I'd be happy to take a test drive with you and observe your driving habit as well as see if I can increase your MPG vs. the way you currently drive the car. Ultimately, you shouldn't be experiencing such low MPG numbers no mater how aggressively you drive unless you are not driving enough miles to complete the warm-up cycle.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The hills in Folsom should be no big deal. My commute from Rocklin to Auburn is nearly a 1,000 elevation gain and I can still manage 46mpg without trying and 48mpg if I try. Flatland trips produce numbers over 50mpg.
    See the pic for my one-way uphill commute.
  5. jgibb
    jgibb jgibb
    Oregon
    My 2005 Prius is also getting very low mileage, 35-40 mpg. When I bought it, and for about 3 years or so, it got 55-60 mpg consistently. Then I moved to western Oregon (wet) where they told me there are special gas additives because of the moisture in the air (?), and the mileage dropped to 45, which I think most people get here. Now it's 35 which I think is unacceptable.
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    As I answered before, please answer the questions at Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new.
    Since you've moved, it's no doubt that you're commute has changed and possibly so have the weather conditions. Cold weather and short trips (along w/many other factors) hurt mileage.
  7. fwbrc51
    fwbrc51 Junior Member
    61
    Fort Walton Beach / NW Florida
    Wouldn't the 12V battery going bad have a significant contribution to low MPG's? If the 12V batt isn't able to hold a good charge, doesn't that cause the HV pack to constantly support the 12V requirements by the car,...and if it's constantly having to use the stored HV battery power to power the electronics in the car, wouldn't the ICE need to be running to charge the HV pack more frequently, which would result in lower MPG's?
  8. bisco
    49,380
    i believe so. ^
  9. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yes, but this is just one of many possible reasons why a person might get lower than expected MPG's. That's why it's better that people answer the questions asked above by "cwerdna" instead of speculating about the very many different possibilities.
  10. tjli
    tjli Junior Member
    Oregon has made the mistake of increasing the ethanol content of its gas and according to my Toyota Service Manager that is the cause of my drop in mileage and possible the other Oregon Prius driver's low mileage. I struggled with the decision to add ethanol and campaigned against it but our Gov was sold a pile of *&&%% and led us down this path. Many studies confirm the drop of 10-15% in efficiency for most vehicles when using ethanol.
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep. And all too often, people complaining about their mileage either never return and/or don't answer any of our questions. :confused: Result? A lot of wasted effort on our part.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Well just think of the upside. People are complaining about 35mpg being bad! When expectations are raised, it is good for everyone. If you are angry about not getting 35mpg in your Prius, then I would expect you would not even consider any car that doesn't have an EPA rating of 35mpg or above in the future.
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    The crazy part is that some of the people angry about their "poor" mileage or mileage drops during cold weather frequently pointing to some other car, usually a cheaper one... But, of course, that other car gets even worse mileage and in most cases can only achieve 35 mpg in the best case(s).
    There's one notable person here (I won't name him :)) who kept whining about his mileage drop and finally got rid of his 2010 Prius in favor of a car w/significantly lower mileage. :confused:
  14. richard schumacher
    7,663
    1,038
    United States
    But it meets his expectations, and that's what really matters :_>
  15. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My wife's XTerra only has a 5% drop in mileage from 18 MPG to 17 in the winter, compared to my 10% drop 47 to 42 MPG. This does NOT mean we drive the XTerra more.
  16. fuzzy1
    10,159
    Of course not. Not only is XTerra's absolute fuel consumption worse to start with, so is its winter penalty.
    Winter fuel consumption change per 100 miles (neglecting rounding):
    Prius summer: 100/47 = 2.13 g
    Prius winter: 100/42 = 2.38 g
    Prius winter penalty: 0.25 gal/100 miles
    XTerra summer: 100/18 = 5.56 g
    XTerra winter: 100/17 = 5.88 g
    XTerra winter penalty: 0.33 gal/100 miles
  17. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    That right there is another reason I prefer the litres per hundred kilometer unit for fuel consumption that we use here.
  18. Waldoprius
    Waldoprius New Member
    Detroit Michigan
    If that’s the case your motor is running constantly , when it’s supposed to be off half the time , reply back for a solution if this is happening
  19. Saqib Khawaja
    Saqib Khawaja New Member
    Lahore, Pakistan
    ----UK----
    May be your hybrid batteries are not working properly or their life has been over. Secondly make sure you do not drive your car at higher RPM by putting un necessary pressure on accelerator paddle to get high pick.
  20. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    I suspect the poster has found a solution of one kind or another in the (almost) 8 years since this was posted.
    Don't hold your breath waiting for a reply.
    audiodave and TMR-JWAP like this.
