Vibration and rattle from Hybrid to Engine
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Dapriusv, Sep 15, 2023.
  1. Dapriusv
    Dapriusv New Member
    New York
    2013 Prius v wagon
    new to the forum. Recently i started to notice a loud rattle/vibration coming from the engine. I can feel it on the driver side even near the gas pedal... once i get to a certain MPH it gradually goes away... it only happens a low speed... when on EV its fine. I did replace the water pump and even the motor mounts which were done so that was needed, but the problem still persists.
  2. Dapriusv
    Dapriusv New Member
    New York
    2013 Prius v wagon
    Any help would be greatly appreciated... Thank You
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    This loud?
    Shudder video
  4. Mendel Leisk
    38,726
    What's the miles, and how long have you owned it?
  5. bisco
    49,488
    You need to clean the egr circuit
  6. Dapriusv
    Dapriusv New Member
    New York
    2013 Prius v wagon
    337000 and about 4 months
    My mechanic said it sounds like the transmission... because the clunking sounds right underneath the driver foot well
    I did clean the manifold and egr pipe today not the egr itself ... should i get that done?
    It only shudderes when driving after maybe 30 mph it goes away...
    #6 Dapriusv, Sep 16, 2023
  7. Mendel Leisk
    38,726
    337k in a 3rd gen means almost a certainty something catastrophic has occurred, typically head gasket failure. That may have been “remedied”, but the damper between engine and transaxle suffered damage, plus head gasket failure maybe happening again.
    if this is the case, EGR cleaning, while good, should be shelved till head gasket is assessed.
    My 2 cents, maybe time to let go.
