Vibration from right rear end
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by spidey, Dec 10, 2008.
  1. spidey
    spidey Junior Member
    81
    central north carolina
    We have a 2009 prius with almost 2500 miles. Recently we have noticed a vibration that seems to come from the rear right end. This seems to occur early on in driving and the weather has been noticebly cooler.
    Any ideas on things to look into since it seems after driving around the noise diminishes some however do hear it every so often.
  2. Patrick Wong
    18,200
    6,479
    Check tire air pressure
    Check wheel balance
    Snow or mud stuck to wheel?
    Rear wheel bearing failure?
  3. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    That pretty much summs it up. I would do this in this order:
    Check for mud stuck to wheel
    Check tire pressure
    Check wheel balance
    Check bearings
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Are you sure it's not the ICE running? It can be a little rough until fully warmed. Sometimes sounds and vibrations are not where you think they are coming from.
  5. spidey
    81
    Well the vibration started when it go colder out lows in upper 20s and 30s and highs in 40's. However last few days we have been back to 64 - 73 degrees and dont hear it at all. The vibration always comes from right rear and now that I think of it our avalon may have done similar in cold. So now I am wondering if its just vibration of the exhaust system till it warms up.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Sometimes if car sits awhile when cold the tires will take a funny shape, ie it will be slow to lose the flat spot where the tire sits on the ground for awhile till tires get warmed up. Also could be a belt coming loose inside the tire.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    We have had that problem after backing though a pile of snow. It packs in the wheel and throws off the balance.
    Tom
  8. jorgeez
    jorgeez New Member
    121
    Installing rear sway bars can probably help.
