Vibration question
Discussion in 'Gen 2 Prius Technical Discussion' started by cdub1955, May 18, 2008.
  1. cdub1955
    cdub1955 New Member
    Lexington, KY
    I have a used 2007 prius. There is a vibration noise coming from the right side of the front compartment, sounds like the glove compartment, but maybe a bit higher and toward the right window posts. I cannot seem to isolate it. It only occurs on some rough highway pavement at about 55 + mph. any ideas?
    Chris
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    There is a plastic shelf in the upper glove box that often causes rattle noises. I wrapped mine in the "anti-slip" stuff you can buy for tool boxes or motorhome cupboards. That stopped the rattle.
