Vibration / rattle at start up?
Discussion in 'Prius v Main Forum' started by Capecodbeachfront, Apr 9, 2020.
  1. Capecodbeachfront
    Capecodbeachfront Junior Member
    55
    2013 Prius v wagon
    2013 Prius V
    At some point this spring I started getting a vibration (more like a rattle) when I first start the car AFTER IT HAS SAT FOR A WHILE. When the car is warm, no noise. When the car switches to Hybrid, no noise. Noise is only there when the gas engine first starts. Car has 80K miles on it if that helps. Noise appears to only last until the gas engine is warm enough to switch to electric. No it is not the LOUD knocking sound you get when car was started for a short time then let to cool. Hard to tell but I believe the sound is 'up' not at the bottom of the engine compartment. I swear it is a loose something but I can not locate it... so far. Anyone have a similar noise? Thank you.
    49,501
    might not be the culprit, but you're just in time for an egr circuit cleaning
  3. Capecodbeachfront
    55
    2013 Prius v wagon
    Just drove the car tonight after day of sitting... Noise is definitely there but maybe more of a 'buzz' than a real rattle. EGR circuit cleaning??? That I need help with.... ? What and where??? thank you.
    49,501
    search the gen3 threads, see @NutzAboutBolts you tube video. it clogs up from crankcase gasses, eventually blowing the head gasket in some places.
    if you're getting a buzzing, maybe a heat shield?
  5. Capecodbeachfront
    55
    2013 Prius v wagon
    Would it throw a code that could be read? So far I am getting no warning lights. Last trip to dealer the desk guy said any thing serious would code. He did listen to the car but by then it was warmed so not making the noise. I may eventually have to leave it overnight, with understanding it should be check immediately in the morning. Any chance this might be covered under my Certified Warranty or Emissions Warranty? Really do not need any extra bills right now.... Need extra cash for stash of toilet paper....
  6. Capecodbeachfront
    55
    2013 Prius v wagon
    We still have some cold morning here but would extra minutes of lower mpg be a sign of the valve not working? I am talking about the 'mpg stacks' on the screen.
  7. vand8
    vand8 Junior Member
    16
    NY
    2015 Prius v wagon
    One possibility is it could be a heat shield. Our CR-V had that issue where some heat shield under the hood would rattle when cold, and then go away as the engine heated up and the metal expanded. If it is a heat shield, I would expect it to rattle more consistently over time until you figure out why it's coming loose. My experience from the past is the shield rusts around the bolt holes until the metal fails altogether around the bolt.
    Air_Boss likes this.
  8. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    We had exactly the same heat cycle rattle issue with our CR-V...
