Vibration when Coasting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Christopher De Leon, Nov 25, 2015.
  1. Christopher De Leon
    Christopher De Leon Junior Member
    San Antonio, TX
    Symptom:
    A vibration that feels somewhat like a bouncing tire
    Cause:
    Coasting in Drive (Applying the gas at all stops the vibration, putting the car in Neutral also stops the vibration)
    Any idea what this could be?
    49,384
    if it was a tyre, wouldn't it remain while coasting in neutral? how many miles on her?
  3. Christopher De Leon
    San Antonio, TX
    I didn't mean to say that I thought it was a bouncing tire, but that's what the sensation feels like.
    125k Miles
  4. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Check the engine mounts.
  5. bisco
    49,384
    any difference with engine running or not?
  6. Christopher De Leon
    San Antonio, TX
    I was again testing last night, and it seems to be vibrating (though less) when I touch the gas still. However it does go away when I press the gas more. This IS starting to sound like an engine mount problem, as I hear, engine mount problems can go away with engine load as the torque of the motor can hold it in place, but when idle or low load the engine is free to vibrate.
    The only thing is, how does this explain the vibration when the engine is off altogether?
  7. andrewclaus
    993
    324
    Golden, CO
    I suppose the transaxle is still being driven by the axles, and that's attached to the engine? Not sure. There's still some braking torque going on in the transaxle with the engine off.
  8. bisco
    49,384
    when you touch the gas, does not mean the engine comes on. you need to do more testing and differentiate.
