Vibration when using engine brake with full battery
Discussion in 'Gen 3 Prius Technical Discussion' started by hikingslo, Mar 6, 2011.
  1. hikingslo
    hikingslo Junior Member
    Central Coast California
    My wife said the car started vibrating pretty bad when she used the engine brake going down a hill when the battery was full. Is that normal?
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yes, the engine is run up to max RPM for maximum engine braking and it does make some noise and vibrate a bit. It won't harm anything. There is no fuel being injected during engine braking so the actual compression forces are quite low. The funny part of this is during the engine braking, if you press on the accelerator even a bit, the engine will -slow down-. Something you don't normally expect. :)
  3. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Already got used to how quiet & smooth the Prius normally is, eh?
    That sound & feel is a bit out of the ordinary, especially for those of us who rarely ever see a full battery. But it is nothing to worry about. When it does that while your not moving, it's quite the reminder of how smart the system is... going out of it's way to maintain good battery health (spinning off excess charge) without you having to do anything.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Scary the first time but normal.
  5. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Why would simple engine braking cause any vibration not felt in normal driving ?
    If anything, running an ICE at the same rpm as when engine braking should have a higher NVH.
  6. hikingslo
    I thought it would be normal, just wanted to check and make sure! Thanks for the info.
