Vibration while idling
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ware, Jan 31, 2017.
  1. ware
    ware New Member
    EU
    Hello fellow prius drivers,
    I've noticed something that does not feel normal to me:
    Sometimes when the car is warmed up and ICE re-starts there is vibration in the cabin, I can feel it through the seat and steering wheel. I have also noticed strange popping sound from exhaust while idling (no necessarily when vibration occurs). The engine seems louder at acceleration (it was not like that when I bought the car). There's a short video:
    Could this be misfire ?
    Background about car:
    EU model, 142000km, second owner, no codes, recently changed spark plugs (DIY) to battle this problem - did not help. It is winter here, so temps are around 0C. Mileage is around 6.5-7L/100km mostly city driving, short distances.
    Appreciate all the help I can get.
  2. b100
    b100 Member
    141
    73
    Netherlands
    Ok, get the codes read. If there a a misfire you should have misfore codes stored.
    Oil level ok?
    Rest of fluids ok?
    When changed sparkplugs?
    Cleaned throttlebody?
    All those things can make your car idle bad.
  3. ware
    ware New Member
    EU
    No codes, Oil ok, fluids ok, sparkplugs changed 2 weeks ago, tb and MAF cleaned.
  4. b100
    b100 Member
    141
    73
    Netherlands
    Do you take it for a long trip sometimes? Sometimes it will help to drive a long distance at high speed to get al the fog out of the engine and oil. Car will may run smoother after that.
  5. ware
    ware New Member
    EU
    Every other weekend I go on a 80km round trip at around 100km/h. I guess I will drive it as is until there are some codes
  6. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Strange that there are no codes. It's rare these days, but could it possibly be bad gas?
  7. ware
    ware New Member
    EU
    I just went through the bills and I see that I ordered DENSO VK16 spark plugs (as opposed to SK16R11). VK16 seem to have 1.1mm gap (which as far as I know is what TOYOTA recommends). Is there any chance my issues are related to the spark plugs that I've just put in ?
  8. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Check engine/transaxle mounts, and look for an exhaust leak? Is the exhaust the normal color, odor and density? By all means, double check the spark plugs.
  9. dolj
    dolj Senior Member
    7,653
    3,866
    Wellington, New Zealand
