video and maybe audio input 2004-2005 models
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Flying White Dutchman, Jan 28, 2008.
  1. Flying White Dutchman
    4,376
    313
    hello
    i got a 2005 prius with the nav on it with the 6 cd changer inside the middle dash
    now i want to put on a backup camera and maybe a audio input!
    i tryed to look in PC search and there is a lot.. info..
    but i want to plug in a composite video feed and a aux line in!
    and not use a aftermarket device but make it with some electronics .. maybe a composite to RGB+H etc?
  2. Tideland Prius
    16,658
    You need a video controller.
    That'll allow you to plug in a camera, dvd player and so forth.
  3. Flying White Dutchman
    4,376
    313
    when the prius diagnostics tells about a camera check i wonder if there is some plug somewhere where i canm simply plugin the video from a rearview cam!
  4. Tideland Prius
    16,658
    You can remove the MFD and check. If there is a way to directly plug one in, that would be awesome. But as far as I know, a video controller is the only option.
  5. Flying White Dutchman
    4,376
    313
    mmmm
    anyone now howe that plug on the back of the mfd looks like?
    any japanes members here?
