Video input
Discussion in 'Gen 2 Prius Accessories & Modifications' started by watalook0869, Mar 3, 2020.
  1. watalook0869
    watalook0869 New Member
    Japan
    I am Japanese.
    Posting via web translation service.
    I'm sorry for the weird English.
    Video input to Gen2 Prius 2005 model (non-nav) was successful.
    It has already been changed to a model (nav) hi-res MFD in 2006, but it is working properly.
    I used the Japanese version of the TV tuner "86010-47010" and the CD player "86120-47140".
    Connect the power line of the TV tuner and connect the Tx + and Tx- of the 5-pin coupler to the MFD 6-pin coupler.
    Connect the composite cable to the 6-pin coupler.
    Connect the 20-pin coupler and 10-pin coupler of the CD player and start the engine.
    When you press the "TV button" on the CD player, the image input to the composite cable appears.
    When you are done, you can remove the CD player.
    Attach it with an appropriate video player.
    Now that I have purchased the US MFD "86110-47210" on eBay, I will install it when it arrives from the United States.
    Thank you.
  2. Frank Tha
    Frank Tha New Member
    Cambodia
    Is there any picture for instruction? Have you completed yet?
  3. 2Fats
    2Fats Member
    101
    61
    Missouri
    I would like to see more pictures of this, please.
  4. Tideland Prius
    16,616
    The things that Japan has that the US does not have. Nice modification!
  5. watalook0869
    Japan
    Hello.
    I installed the MFD I purchased on eBay because it arrived.
    The result was bad.
    The North American version doesn't seem to have a composite video input.
    I recognized the Japanese version of the TV tuner, but could not switch to TV mode.
    ayaz farrukh likes this.
  6. ayaz farrukh
    ayaz farrukh Junior Member
    Can you share wiring diagram or photos while making connections?
  7. watalook0869
    Japan
    There is no connection diagram for it as it failed in US version MFD.
    Can I use the connection diagram of the Japanese version MFD?
  8. ayaz farrukh
    Can you share wiring diagram or photos while making connections? We in Pakistan have lot of JDMs.
  9. watalook0869
    Japan
    Please show me the picture of the MFD when the engine is started and the picture of the coupler on the back side of the MFD. May be helpful.
  10. ayaz farrukh
  11. ayaz farrukh
    Sorry for replying late.
    MFD of my Prius is this. Unable to took photo from behind
  12. watalook0869
    Japan
    Wow! It's a late high-quality version!
    What happens when I press the TV button on my CD player?
    If you switch to TV mode, the Prius will have a tuner.
    The tuner is behind the left rear seat.
    I think there is a blue coupler, so if you connect an external input adapter for Toyota DOP navigation to it, VTR mode will appear.
    In order to watch while driving, the parking brake line and vehicle speed line on the back of the MFD will be visible.
  13. ayaz farrukh
    Thanks for your reply
