Video of CF-18 crash
Discussion in 'Fred's House of Pancakes' started by Airbalancer, Jul 24, 2010.
  1. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
  2. Tideland Prius
    16,153
    Saw the photos... that was a huge fireball
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  4. Airbalancer
    892
    73
    Cobourg, On, Canada
    Ooops could a mod fix it
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    The Pilot was ovehead mutteing, ...
    "That's not coming out of my Paycheck is it???"
  6. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
    The engine went "pop pop pop?" sounds like he ingested a bird, lost power and stalled.
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    couple more degrees inverted and he'd have ejected right into the ground....lucky that. Also lucky the chute didn't ignite. Close close call there.
  8. Airbalancer
    892
    73
    Cobourg, On, Canada
    I think popping is the bolts for the canopy exploding before he ejected
    Not much left of the plane :eek:
  9. Jimmie84
    Jimmie84 New Member
    1,074
    77
    Minnesnowta
    Engine failure.
    You seen it Yaw out a bit as it fails. Glad he's doing ok and was able to eject.
    Look at the nozzle settings on the engine. One's fully open, Other is closed.
  10. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    If you look at the video at 1:00 mark (1:50 Time at the right of the seek bar) you can see one of the engine is puffing out black smoke then a few seconds later the jet veer off to the right. That's when he ejected.
  11. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    A pilot that DID go past the envelope
    The USAF had a pilot in the 90's that was pushing boundaries on B52's....did stuff like have rivets pop off the plane. An officer in vain appealed that this hotdoger be told to stop. In what was to have been the final airshow before they got desk jobs, the protesting officer chose bravely to be the co-pilot to hopefully avoid anything going wrong....tragically there was no time as Lt Col Bud Holland did a deep bank going too slow, taking half a million pounds, and three crewmember down in a fireball. :(
    The USAF no longer allows that behavior.
    1994 Fairchild Air Force Base B-52 crash - Wikipedia, the free encyclopedia
  12. fuzzy1
    10,167
    Re: A pilot that DID go past the envelope
    My recollection of regional news was that such behavior was not 'allowed' then either, which is why so many AF careers ended with the investigation. But this is not reflected in the Wikipedia article.
    Other than the actual crash video, my next strongest memory of this event was news interview footage of [ame="http://en.wikipedia.org/wiki/Sheila_Widnall"]Sheila Widnall[/ame] stating emphatically that these aircraft are never banked more the 30 degrees, punctuated with footage of previous Bud Holland airshow stunts banking them at 85-95 degrees.
