[video] repairing shock absorber on a Prius (worth it?)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by abubin, Jan 17, 2022.
  1. abubin
    abubin Member
    188
    92
    Malaysia
    My shocks are already not working in good condition. I figured, why not get it checked by specialists to see if it can be repaired. I know generally it is better to have them replaced with new but this TRD shocks that I am using is not cheap. Repairing it only cost me 10% of buying new.
    So why not? Let me test it out to see if this is a viable solution.
  2. Kenny94945
    Kenny94945 Active Member
    845
    422
    Sausalito
    2016 Prius v wagon
    Interesting.
    Sure a TRD shock would be worth a rebuild.
    In the video, to me, it did not show the show the repair, seems to be only removal, test, and reinstall.
    For DIY, an oil change and gas recharge are standard, at least with racing vehicles.
    I'd question the gas recharge, maybe utilize a sharder value.
    The oil weight, volume and gas pressure plus all the seals would be needed info and parts.
    Again, Interesting.
    Yes a specialist for TRD maybe a good idea and cost effective.
  3. ChapmanF
    17,966
    The part of that I really want to watch is welding the hole shut with pressurized oil and gas inside.
    The rest of the steps sound pretty easy.
  4. Tombukt2
    Tombukt2 Senior Member
    12,846
    2,308
    Durham NC
    Some type of one-way valve fitted to the case used for filling and removal afterward or from then on I didn't realize stress are so expensive at the present time usually we've just replaced
  5. abubin
    abubin Member
    188
    92
    Malaysia
    Unfortunately, the owner did not allow me to video him with the shock repair. Apparently it is secret that he does not even allow his staff to see. He went into a covered room and did his thing.
