Viewing 12v battery voltage from menus
Discussion in 'Gen 4 Prius Technical Discussion' started by fsu23phd, Sep 20, 2021.
Tags:
  1. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    Hello, I have a 2016 (two eco) showing signs of low 12 v battery. This is my 3rd prius. On my old 2005 and 2010s, I could check the battery health from a top secret hidden menu.
    I can't figure out how to find the top secret menu for my 2016 on Google. Does anyone know how to do this? Also, what at what voltage should I replace the 12v battery? Thanks!
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    This might help -
    dig4dirt likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You can't trust the onboard readings to diagnose the health of a 12 V battery.
    Have it tested at a battery store, auto parts store or dealership.......usually for free.
  4. fsu23phd
    186
    114
    Wilmington, NC
    Ok, I figured it out. Start to accessory mode (don't hold the break). Then hold the car button (near the radio in the two eco) and turn the lights on and off 3 times. The battery health is under Vehicle Signal. Looks like I need a new battery.
  5. ChapmanF
    18,919
    In the earlier generations, the top secret instructions for getting to the Vehicle Signal Check screen were hidden away in the *cough*repair manual*cough*, very cleverly where no one would think to look. (more info)
    I don't know about the 2016 for sure, but it's possible the instructions could be in the *cough*same place*cough*.
  6. Mendel Leisk
    42,219
    I wouldn’t rely on the car displays, even to give accurate voltage, never mind battery health.
  7. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    what's "the car button" you speak of? post a pic
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Probably.
    It is usually pretty easy to verify that a battery is really BAD.
    Verifying that it is "good" often is a bit trickier.
  9. burrito
    burrito Active Member
    274
    114
    It's literally a button that says "CAR" on it. The buttons are different based on what features you have, so you won't have that button if you do have the factory navigation system installed.
    FuelMiser likes this.
