VIN on door plate doesn't match VIN on computer
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius Sapien, Dec 10, 2008.
  1. Prius Sapien
    Prius Sapien New Member
    Cambridge, MA
    Just got my '09 inspected and was told that the VIN that the car's computer uses to communicate with the inspection system does not match the VIN physically located on the door plate. The dealer says don't worry, they'll fix it, but I'm wondering if I should be on my guard about the legitimacy of the car for any reason. The dealer is reputable and I had the (now) standard wait of 3 months for the car to be shipped/allocated.
    Anyone had a similar problem--is it common, easy to fix, and not worth worrying about?
  2. Patrick Wong
    18,200
    6,493
    I haven't noticed anyone reporting this issue before. Yes, the VIN has to be programmed into an ECU, sounds like a weird production mistake happened to your car.
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I doubt it is production mistake. I suspect the ECU has been replaced.
  4. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    I wonder if the computer reports the VIN in Hexidecimal?
  5. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    No, it's in Japanese. :D
  6. tundrwd
    tundrwd Member
    111
    "South Central" KS
    Nahh... It's in Octal, with a Japanese accent.
  7. Bob64
    1,540
    93
    Virginia
    Are you sure its not in binary with subtitles? :p
