vincheckup says trim four but 2015 is a 3?
Discussion in 'Gen 4 Prius Main Forum' started by Brandon D, Sep 23, 2023.
  1. Brandon D
    Brandon D New Member
    Jax
    Is my car a prius 3 or 4? vincheckup website says Trim: Four. but 2015 is supposed to be Gen 3 right? Trying to learn more about the car to get proper answers to questions in here.
  2. Tideland Prius
    16,123
    There was a Prius Four for 2015. The main difference between a Three and Four trim level for 2015 is cloth versus SofTex.
    Brandon D likes this.
  3. ChapmanF
    15,409
    There are generations, and there are trims.
    Generations: 2001–3 was Gen 1, 2004–9 was Gen 2, 2010–15 was Gen 3, and so on.
    Trims: in each generation, you could buy the car in different trim levels, which came with different stuff.
    Mendel Leisk and Brandon D like this.
  4. Trollbait
    11,495
    Toyota didn't use their usual trim designations(LE, XLE, etc.) with the Prius until about the halfway point of the gen4's life. Before that, it was just numbers.
    Pulse07 and Brandon D like this.
  5. Brandon D
    Jax
    do I have an alternator or an inverter? anyone know what the safe draw limit is for whichever?
  6. Trollbait
    11,495
    No alternator on a Prius. The 12V components and accessories are supplied power by a DC-to-DC converter that steps down the voltage from the traction battery. The inverter on the car switch the current between AC and DC between the motor/generators and the battery.
    M/G1 replaces the alternator functions, as it is virtually always making electricity while the engine is running.
    Pulse07 likes this.
  7. Mendel Leisk
    38,635
    And before that, at least for 2010 model year, in the States, it was Roman Numerals (I through V), which created a bit of confusion when the Prius v (a distinct model from Prius) came out, in 2012.
    Our 2010 Canadian "Touring" Prius is comparable to a US Prius V, albeit stripped of some of the high tech stuff.
    This is a REALLY good resource for older car brochures:
    Auto-Brochures | home
    #7 Mendel Leisk, Sep 25, 2023
