VIOFO A129 PRO DUO 4K INSTALL
Discussion in 'Prime Audio, Electronics, and Infotainment' started by chickenhawk, Jun 2, 2021.
  1. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Here is the Hardwire Parking Kit install with pics on my '21 Prime. One note is the rear camera dose not have usb connection on side, so this is why i installed on the trim instead of widow as it will push the camera further down on rear window. I connected the constant power to red wire of dome light and the acc switch power to the green wire on lane departure sensor connector .
    Make a small notch at the center edge of the trim where the wire for camera will pop out. This way the trim will not pinch the wiring. Also make sure all the blue clips are on the trim and not on the car body. Just remove them from the body and slide back in onto the trim.
    Pull the rubber piece off first then squeeze the 2 clips on each side to pull the white plastic out.
    20210413_154443.jpg 20210413_153648.jpg 20210413_153836.jpg 20210413_153908.jpg
    After you route the wires through, put the black rubber conduit back onto the white plastic before install it back in.
    20210413_154959.jpg 20210413_155325.jpg 20210413_155406.jpg 20210413_155652.jpg 20210413_155708.jpg 20210413_155853.jpg
    *MAKE SURE YOU ROUTE THE WIRE UNDER THE AIRBAG AND UNDER THE BLACK WIRE HARNESS AT THE TOP BEFORE RUNNING THE WIRE ALONG THE TOP TO THE DOME LIGHT OPENING.
    Install the ACC wire to the Green wire of the sensor connector.
    Install the constant 12v to the red wire and the black ground to white/black stripe of the Dome light connector.
    Installed the rear camera base into the trim with 2 blind rivets ( I tried the 3M tape but it won't stick as you all know)
    #1 chickenhawk, Jun 2, 2021
    java007md, marke16, SFO and 1 other person like this.
  2. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    Awesome post, I'll have to come back to it when if I ever get to installing a rear camera.
  3. roguetadhg
    roguetadhg Junior Member
    23
    2023 Prius
    Limited AWD-e
    Fantastic! Not a prime owner, but I've been trying to install my A139 and the tips are helpful :)
