Violent EM disengagement slowing at 9 mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by szabi, Nov 3, 2009.
  1. szabi
    szabi I also have a 2007 Prius
    25
    200 mi N of SF Bay area
    Prius 2008, 17.5K miles. I am an engineer & have put 25K miles on 2 Priuses since 2007.
    The car is completely warmed up, pavement is dry and clear, weather is mild, temp. 60F. I am coasting in Drive, beginning at 30mph, towards a stop sign with foot off the accelerator. I apply the brake at 20mph. As I pass through the transition from regenerative slow-down to brakes at 9 mph, there is a single violent shudder through the drive train, but no sudden slow-down. I am aware of what the normal transition is like; this is about 10 times more violent, really disturbing. There is no bang or other noise.
    This has happened twice in 3 weeks, at 2 different locations. No indications from the monitor lights or other readouts.
    Has anyone else experienced this? Any diagnosis or advice?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This sheds suspicion on the friction brakes. I can't see where the HSD would cause this, but it is easy to see how a friction brake problem could cause a shudder at the transition.
    Tom
  3. szabi
    25
    Quite possibly. But why would it occur rarely and intermittently? If it IS a brake problem, I would suspect a problem with the brake boost actuators or their controls.
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Have you tried making it do this at low speed in neutral? Since it is intermittent it would be hard to prove the negative, but if it did it while in neutral you could isolate the problem to the friction braking system.
    Maybe there is some stickiness on the rails/mechanism of the friction brakes (sand/gravel/flash rust.) You might be able to clear this with some solid braking in neutral from moderate speeds.
  5. szabi
    25
  6. richard schumacher
    7,663
    1,038
    United States
    Presumably you have experience with Prius brake grabbiness in damp weather? and this ain't that?
  7. qbee42
    18,058
    3,074
    Northern Michigan
    These are my thoughts as well.
    Tom
  8. szabi
    25
    Definitely not. Tnx.
