visability
Discussion in 'Gen 2 Prius Accessories & Modifications' started by speedo, May 6, 2005.
  1. speedo
    speedo New Member
    Hi I own a 2005 prius,and really like it so far except for
    the drivers side mirror.Can't seem to adjust it without
    having a large blindspot.It is really not safe.I've already
    had a couple of close calls with this problem and i'm sure
    alot of other owners have noticed it too.If anyone has come
    up with some sort of solution to this please let me know.I
    would really appreciate it.I owned many cars before this one
    and was always able to adjust it so there was hardly any blindspot.
    Help Bob
    Silver Prius
  2. catsbox
    catsbox Member
    295
    Bellevue, WA
    I have not noticed the problem with my Pri as badly as I did with my Matrix. For my Matrix, I put those small stick-on round mirrors on both side-view mirrors. Really helped with the blind spots.
  3. ammiels
    ammiels New Member
    121
    brewster, ny
    This has been discussed before, but basically if you adjust the side mirrors so you have to lean your head against the window or put your head to the middle of the car in order to see the door handle you will have no blind spot. Between the rear mirror and the side mirror everything is visible. Try it out.
  4. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    ... people don't look over their shoulders to see their blind spot? i thought this was required
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Nope, I never noticed a problem. Using blind-spots mirrors since back in the 80's eliminated any concern about what's on my sides.
    Here's a close-up of the one on my HSD Prius... http://john1701a.com/prius/prius-album73.htm
  6. speedo
    speedo New Member
    Hi
    It's me again I don't think I explained well enough for you people
    to understand the situation.When i'm driving on the highway and
    in the slow lane,cars will be passing on my left.At times I've looked
    in my drivers side mirror to change lanes there was no sign of a car
    in my mirror,so I started to change lanes,just as I did a car was right
    along side of me and I had to swerve back quickly to avoid him.
    Whoever it was that said i'm not moving my head in different positions
    is all wet.Believe me this is a problem i've never had with any other car.
    Anyway will the blindspot mirrors help with this type of problem?
    Thanks Bob
  7. raybon
    raybon New Member
    36
    Boulder Creek, CA
    I was taught in driver's ed. class (12 years ago) that not only do you look in the mirror, but you also check over your left shoulder to make sure the lane is clear.
    You may want to try one of the sticky mirrors mentioned in the posts above.
    Glenn
  8. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Can any moderator or administrator please edit the title of this thread to correct the spelling of the word VISIBILITY.
    Thanks.
  9. Tideland Prius
    16,155
    Adjust your mirror so that the car would be in view in this sequence
    rear view, driver's side, peripheral vision.
  10. rookie
    rookie New Member
    61
    Frisco, TX
    Geez it scares me to death that people do NOT turn over their shoulder and rely only on the mirrors! :s
    Back in Croatia (where I am from) - if you do that on your driving exam - you fail. It is a MUST.
  11. Breezy
    Breezy New Member
    26
    Milwaukee, WI
    John,
    Thanks for sharing the link to the photo. Where did you get the blind spot mirror from or what type is it? I did a Google search for "blind spot mirror" but didn't seem to find any that looked like yours.
  12. majordude
    majordude Member
    119
    "The OC"
    <div class='quotetop'>QUOTE(rookie\";p=\"87785)</div>
    You have it soft in Coatia. There, everyone is Croatian.
    Out here in SoCal, we have millions that just three weeks ago were driving rickshaws, burros and camels.
    Now they have cars and drive slow in front of me and fast behind me.
  13. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I do not have a problem either as long as I do a left shoulder check. Make sure you have the mirror adjusted so you can see the front of the car on the left, not just the windshield. If it is too high, you won't see a car there nearly as early.
  14. speedo
    speedo New Member
    Hi
    I'm so glad most of you people could understand
    my problem.And then there's always a few who
    can't I guess it's do to lack of intelligence.Well I
    found the answer to the blindspot here's the link.
    http://www.cs.wisc.edu/~gdguo/driving/BlindSpot.htm
  15. ammiels
    ammiels New Member
    121
    brewster, ny
    That's what I said up at the top.
