Visiting a 2001 Prius
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Mar 4, 2010.
  1. bwilson4web
    16,353
    I visited the owner of a 2001 Prius with 250k miles and a few maladies. The first visit was finding the location and diagnosis. We talked and later I sent follow-up e-mails. But I wanted to bounce my findings off the community. One thing that warmed my heart was the owner had the 2001 shop manuals and electrical diagram book. I brought my Graham mini-scanner to read and reset the codes.
    ENGINE
    The owner reports 'it uses oil' and it had been 'de-carbonized.' Inspection of the throttle body indicated it needed cleaning but it wasn't sticky. The owner reported one starting event last summer.
    The engine started and warmed up normally. We cleared the codes and took it for a test drive with the steering ECU enabled.
    CATALYTIC CONVERTER
    The owner reported "reduced efficiency" from an earlier code. Monitoring the O{2} sensors showed both reporting pretty much the same values. I explained that burning or using oil is death to catalytic converters. Repairing the catalytic converter and/or O{2} sensors makes no sense until the root cause, engine oil consumption is fixed first.
    STEERING TORQUE SENSORS
    The steering sensor 'jitters' had occurred. So the owner has the steering ECU power routed through a switch between the light adjustment and outside mirror adjustment control. By powering off the ECU, the car is more stable as there had been an event at high-speed. The user reports having seen the steering rock on its own. Normal operation is in manual mode with the PS light.
    During the test drive, the steering behaved normally. However, we discussed the possibility of using a pair of pi filters to take out the electrical noise. Later examination of the manual shows a 0.5-4.5 VDC range, which means electrolytic caps and chokes should work. But testing the steering fix safely needs to be planned ... perhaps reducing motor power with a load resistor.
    TRACTION BATTERY
    The battery ECU showed P3011, bank 1 weak. During the test drive and monitoring, there was a 0.20 V difference but bank 1 was always listed as the low pair. The owner reported a recent cross country trip was interrupted with the fan running and visiting a dealer who reported the battery needed replacement. Obviously bank 1 is marginal. The car had the terminal sealant applied at the dealer.
    I left a pair of used modules for experimentation, the owner installs PHVC systems and solar systems. We discussed options of removal, inspection and test; replacement of two weak modules with refurbished; rebuild using NHW20 modules; replacement with salvage battery; and contacting "Re-InVolt."
    I also explained that error codes and indications can be cleared by disconnecting the 12 VDC battery. I also sent a note about jumpering the OBD to cause the codes to flash out.
    OPERATION
    I shared that cruising at 65 mph returns excellent highway mileage and when climbing hills, 55 mph puts a minimum stress on the traction battery. I suggested using semi-trailer trucks as a pacing vehicle as the ones that cruise at 65 seem to have a Prius friendly driving profile since they also need to save fuel.
    RECOMMENDATIONS
    The traction battery is most at risk. This may be a case of one or two weak modules. The low cost solution is to remove and inspect the battery with a spare pair ready. Check and clean the buss bars and re-install the battery. The two removed modules can be tested offline for capacity as a measure of pack health.
    Inspection: two people, 8 hours, $50 modules
    Rebuild: two people, 8 hours, $500-1,500 modules
    Rebuilding the engine, either a top-end or whole build, is the next priority. Although oil burning engines can run for hundreds of miles but the risk is eventually a combination of high temperatures and low oil can lead to an engine failure. The spark plugs can also coke-up and need cleaning or replacement. However, there is no evidence of other mechanical issues. This can be deferred but there are two versions of rebuild, cylinder head only, or bottom end too.
    Valves: one person, 8 hours, 3-4 days for shop, $400 est.
    Bottom: one person, 24 hours, 7 days including shop, $600 est.
    Swap salvage: one person, 16 hours, no shop (thanks Patrick), $800 est.
    Steering ECU has an acceptable workaround: a power switch on the ECU. When power assist is needed, it can be turned on. I would like to try a pair of pi filters but that isn't my car. Testing remains a risky venture suggesting depower or reduced power to steering assist motor until confidence in system returns. I do have a failed steering assembly that I need to run forensics on.
    pi filter: one person, 2-4 hours, $20 or less
    steering replacement: one person, 8 hours, $1,000
    Catalytic converter does not need to be touched until the engine oil consumption is fixed. The O{2} sensors appeared to work but if they fail due to carbon coke-up, fuel efficiency will drop dramatically.
    O{2} sensors, one person 2-4 hours, $50
    catalytic converter, one person 4 hours, $200, muffler shop, $250
    There is no record of transaxle oil or inverter coolant change. I'd recommended doing a combined, engine oil, inverter coolant and transaxle oil change:
    engine oil: one person, 1 hour, $25, filter and 4 quarts
    transaxle oil: one person, 1 hour, $25, gasket and 5 quarts, Type T-IV or Type WS
    coolant: one person, 1 hour, $25, pvc hose to bleed air
    This raises the question of when should a non-crash vehicle be retired? Should this troubled car be sold, eventually winding up in auction? Personally, I see this car as Do-It-Yourself servicable. They have spare vehicles, a shop and skills to keep it running. I'm also willing to come back, they are about an hour away, and 'turn a wrench' ... its a Southern' Thang you might not understand.
    Some of the 'patch' fixes make sense by opening the shopping window for replacement parts on Ebay. The rule of thumb is: Good, Fast, or Cheap, pick two. By expanding the window to shop for parts, better quality can be gotten for a relatively low price.
    Thoughts?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Tricky one.
    If it were mine I'd sell or scrap it as it's beyond my experience to fix it myself and not worth the money to pay someone else to do it.
    You have the experience Bob and maybe you could use this vehicle as a 'project' car for a hobby over the summer?
  3. bwilson4web
    16,353
    We have enough Prius already but I don't mind 'turning a wrench. <grins>
  4. Patrick Wong
    18,210
    6,512
    Hi Bob,
    A few thoughts regarding rebuilding the engine:
    1. Have a shop perform a cylinder leakdown test to determine whether the oil consumption is due to worn cylinders or the head.
    2. If the cylinder head, then a machine shop could rebuild it.
    3. If the block is worn, then I'd suggest replacing the engine with a salvage unit since those are pretty inexpensive.
    In general, I would say that if the owner had to rely upon dealer service to repair all of the issues you listed, it would be time to scrap this vehicle.
  5. bwilson4web
    16,353
    I wonder if the salvage engine, possibly engine and transaxle, are bought at one time, does it make sense to do the heads and bottom overhaul before installation?
    My thinking is we only have the salvage yard's report of the vehicle state and no idea of what the original owner had been doing. With the engine out, it is a lot easier to do the head, bearings, and rings. In effect, installing a rebuilt engine, not just a salvage.
    If the engine and transaxle are bought as a unit, then any future transaxle replacement can be handled using the spare. Alternatively, put all parts back for sale on Ebay to recoup part of the purchase price (and clean out the shop.)
    Now I noticed they also had a slightly rusting VW MicroBus body and with a little sheet metal work ... hybrid MicroBus. <GRINS> ... Better be careful, I could spend all summer there.
  6. Patrick Wong
    18,210
    6,512
    Hi Bob,
    Well, if you are determined to rebuild the engine then you might as well rebuild the original, no need to buy the salvage engine unless you find some flaw, such as a crack in a cylinder wall (which would be manifested by coolant in the oil and vice-versa) ...
    With aluminum blocks, there may be a limit regarding how much wear can be compensated for. Over-size pistons and rings should be available but there's probably a limit regarding how much the cylinders can be bored out. Probably should check your manual to see what the limitations are.
  7. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    Maybe this would be a good car to experiment with making it a full-EV. Just take all the engine parts out, except for the block to give support. Then put a big 273V battery pack of some kind back there with a charger.
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    Re: Salvage engine - I don't believe that there is any significant difference between a Gen 1 and Gen 2 engine, which would mean that you have a large donor pool of potential replacements. I think this would be the less expensive route over paying for a rebuild.
  9. bwilson4web
    16,353
    <AHEM>
    250,000 miles / 10 years ~= 25,000 miles / year
    If we can develop a battery that runs on air and gasoline or diesel, I think we have a winner. <wink>
  10. adric22
    642
    146
    Fort Worth, TX
    When I suggested turning it into an EV, I was sort of making the assumption that the original driver would be selling the car and buying something else. In which case, somebody on here could buy it cheaply as an experimental platform.
  11. tochatihu
    tochatihu Senior Member
    9,851
    3,813
    Kunming Yunnan China
    2001 Prius
    Dr. Wilson makes house calls!
    Bob, you are way out front in terms of filtering the steering torque sensor signals. Demand for such a product will increase, and if you can devise a simple plug-in system I predict it will be a winner.
    On the 'slightly rusted' VW bus, I'd like to suggest that there may be more structural damage than may be immediately apparent. I usta look at a lot of those :)
  12. bwilson4web
    16,353
    Hummm, I have this idea ... swap steerings. I don't have a failed steering assembly and the skills to deal with it. He has a failed steering assembly but doing 25k miles/year, may not have the time to fiddle with it. ... Hummmm.
  13. jk450
    jk450 New Member
    55
    Did you record freeze frame data before clearing the codes?
  14. bwilson4web
    16,353
    The Graham Miniscanner doesn't have that capability. If you get a chance, Google it up. For the price, it is a handy unit but not as fully featured as the Toyota or Autoengiuity (sp?) units.
  15. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    For the steering issue, here is an autospeed article on reducing the power input of the steering motor with a few simple components...It's for an NHW10 but I'm sure it would work on the 11 too.
    Modifying Electric Power Steering
  16. jk450
    jk450 New Member
    55
    By clearing the codes, you have erased the freeze frame data.
    That data is designed to facilitate diagnosis of the issue that triggered the code.
    It cannot be retrieved once it has been erased.
  17. bwilson4web
    16,353
    It is one of the best features of the Graham miniscanner. This means we don't have to clear the codes by disconnecting the 12 VDC battery and also lose the fuel trim data. It really is a dandy part:
    The Prius Mini-Scanner Project
    As NHW11s come out of service, I have a standing offer to buy any Graham mini scanners so I can rent them to others who need a scanner. Just another contribution to the community.
    So are you planning to build and sell a "freeze frame data" display device?
  18. jk450
    jk450 New Member
    55
    I'm not sure that this qualifies as a ringing endorsement.
    Again, why would you want to clear codes on a vehicle with an existing problem, using a device which erases diagnostic data that has not been retrieved? Do you think the data is irrelevant to the fault?
    Let's say that someone rents one of these gadgets from you, and uses it to "turn off the warning lights". Let's say that they then decide to have the vehicle professionally diagnosed. A competent technician will go straight to the code, the information code, and the freeze frame, which will contain data recorded by Toyota that is considered relevant to the specific fault. They will then evaluate the data in context.
    If the information has been erased, the technician's job will be made more difficult, and he or she will have to invest more time to diagnose the problem. The customer will be paying for that, by the way.
    What, in this case, is the contribution to the community?
    Why would anyone want to? They are commercially available.
    I'm sure it took a lot of work to develop the mini-scanner. I'm sure it's useful to enthusiasts who want to watch the inner workings of their vehicle. But it is extremely limited as a diagnostic device, and the manner in which you are using it does not make sense.
  19. bwilson4web
    16,353
    We did this to determine if it is an intermittent or hard failure. It was interesting that during the test drive we didn't see the codes come back. Regardless, we were able to verify:
    • O{2} sensors showing the same values - reduced catalytic converter
    • Module pair #1 consistently showing the lowest voltage - the P3011 code cause
    • Steering jitter did not return but we know it is intermittent - he has a workaround that powers off the steering ECU
  20. tochatihu
    9,851
    3,813
    2001 Prius
    The Graham Davies miniscanner is indeed useful for the technical enthusiast to watch what's going on (but keep paying attention to cars and other nearby objects please!)
    In addition it can tell you when the HV battery gets a bit too hot, which is not uncommon in the NHW11. I consider that a very important application.
    Not really linked to the main idea of this thread, but I just thought I'd stick my nose in.
