Voice command button for non touch screen HU
Discussion in 'Prius c Technical Discussion' started by ROLOPR, Sep 22, 2012.
  1. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    When I was on the dealer doing the Prius C maintenence, while waiting I look for the 2013 Tacoma model.
    For my surprise the one with the standard radio has the Voice Command button, while the one with the Touch Screen radio NOT have such button.
    With the above mention, My Prius C have the Standard Radio and the spot for the Voice command.
    Two question came:
    1. Are the wiring from the steering wheel to the radio is build in so I can purchase only the VC button?
    2. Can the VC work on Standard Radios too?
  2. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Pictures are better than words about the topic
    Standard Radio with Voice Command:
    Touch Screen without Voice Command:
    Make sense on the Standard Radio?
  3. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    Is that way different from the Prius c sold in the US. . . Not sure hopefully someone out your way will see this and be able to Enlighten us
  4. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    My 2012 CDN base model (C2 equivalent) has the standard radio and phone down/up buttons, but no voice command button.
  5. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Me too. I wonder if it is pre-wired so I only have to add the VC botton
  6. wmo168
    wmo168 Member
    239
    49
    South Florida
    Yes it is pre-wired and it use the same signal wire for phone on and off. You just need add the switch in the steering column.
  7. DanMan
    DanMan Junior Member
    Guys guys guys......that's a picture of a Tacoma! Not a Prius. And OP, yes the touch screen does not have a voice command because that unit does not have navigation. It was way to cumbersome to use the manual controls without the touch screen for bluetooth, that's why they had it.
    It's likely a totally different radio than you have in your Prius, so comparing it isn't helpful.
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Gah, I'm an idiot... it says Toyota on the radio...
