Voice command question
Discussion in 'Newbie Forum' started by Behindblueii, May 4, 2011.
  1. Behindblueii
    Behindblueii New Member
    Lyndhurst, NJ
    Ok I just got my Prius IV and I love it. I'm trying out my voice command and when you press the button the voice goes through examples of commands you can say. Is there a way to shorten that to have her say... Say a command (beep) or just a beep? Or do I have to listen to her go through her speech? Any tips or help is appreciated...
  2. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    You must be asking about navigation. I do not have that as I use a Tom/Tom with Mr. T's voice.
    Congrats on your new Prius and welcome to PriusChat. :welcome:
    Someone will get you a solution.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Yes the voice prompts can be turned off. It's in the manual. I don't have mine handy.
  4. Chris2128
    Chris2128 New Member
    85
    Oklahoma
    Just double click the voice button and you will only hear a beep !! No annoying lady voice! You can also make her stop talking when u press the voice button during her speech. Try that and let me know how that worked for ya ;)
  5. Behindblueii
    Lyndhurst, NJ
    I tried both... Pressed the button twice and found out how to turn the prompts off... Thanks guys... Now one more question... Sometimes when I hit the voice command and say audio it says that is not available at this time... But I can say iPod and it works... Anyone know why?
  6. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    So these are separate? I haven't been able to figure out how to turn the prompts off unless I press the button twice... And yes, I have read the manual :)
  7. Behindblueii
    Lyndhurst, NJ
    Sorry for the delay ... Go to set up/ voice/ voice recognition guidance ... Turn it off .... This should help :)
  8. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    Thank you so much! I had skipped past that option over and over again. I'm guessing I had a mental block with the "guidance" reference. It is now happily silent!
    Thanks again!
