Voice navigation not starting
Discussion in 'Gen 3 Prius Audio and Electronics' started by lex, Jan 23, 2023.
  1. lex
    lex 2005 Prius, always garaged
    119
    16
    Fresno
    Recently the voice navigation has failed to start after entering a destination (a previous destination, a set destination, or a new one). Once hitting "Go To" I expect the route to be calculated and the voice guidance to begin as normal, but something prevented it. Shutting off and restarting the car seemed to resolve it, then it occurred days later. I've searched the threads but mostly found responses to how to update the maps.
    This is a 2010 Gen 3. Any assistance appreciated!
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    There should be a mute "button".
    Any chance that was activated by mistake ??
  3. lex
    119
    16
    Fresno
    I can't recall the exact unfolding of events while using navigation, whether as normal or in this last development, but I believe even the screen was not showing the guidance according to the input destination after commencing. But, yes, there's a chance it's been muted, though I'm not aware of such a button. Where is it? Thank you —
  4. sam spade 2
    7,035
    2,803
    2017 Prius c
    Can't say with your model.
    It should be right on the map screen off in a corner.
    But in my C, I think it is on a sub-menu and WAY too hard to find.
  5. lex
    119
    16
    Fresno
    It's a 2010 Gen 3. I've combed through the menus and guide on many an occasion without seeing it. Someone here will likely know.
    #5 lex, Jan 24, 2023
