Volt Battery fire(s)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Nadler, Nov 29, 2011.
  1. Nadler
    Nadler Junior Member
    25
    Long Island NY
    GM is now loaning replacement vehicles to any Volt owner who would like one, because of the possibility of a battery fire after an accident.
    Anyone know if the batteries in a PIP are similar to a Volt's and whether we face similar issues?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    They're very dissimilar. There is not a liquid cooling system like on the Volt. Current speculation is that when the Volt's lithium battery case is breached AND the liquid coolant line is breached AND the liquid coolant gets on the battery (ie. only when there is a roll-over incident) AND enough time passes that a short can be created that can cause a heat build up, sparking and potential for ignition.
    There is no liquid coolant system for the PIP. Certainly there is always some possibility that damage could cause a short and potential heat build up and potential fire. But, apparently, as long as you're out of the vehicle with major battery damage within 6 hours you should be safe.
  3. evfinder
    evfinder Member
    293
    72
    Actually there was only one battery fire, the other two Volts involved in fires were victims not the cause of the fire. The only issue was the fire at the NHTSB facility 3 weeks after the battery was compromised in a crash test. A new protocol is being introduced that will drain the pack after it is compromised in an accident.
    With a car there is always a risk of fire. If a car catches fire and burns a house to the ground it gets a short blurb on page 23 of the local rag. If a Volt is involved in a fire then it get front page treatment, it's all part of being the new kid on the block.
    The NHTSB has stated that they don't consider the Volt to be anymore of a fire risk than a standard ICE car.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    Volt also has a 360V battery heater that runs off the high voltage battery. That is supposed to heat up the coolant to warm up the battery. That needs to be looked at as well.
    For PiP, the battery is air-warmed from the cabin. If it is very cold, the cabin gets the heat from the gas engine combined with the heat recycled from the exhaust.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It's a conspiracy to allow GM to take back the Volts like they did the EV1 a decade earlier. :D
  6. oldasdust
    oldasdust Member
    356
    47
    illinois
    How is the pip battery cooled, fan from cabin air temp? If so then maybe Gm should have learned from toyota. More damage control for the volt with gas prices down how are they selling ??
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    ^^ Let's just say the fan expectation of msrp for years has been a couple years too optimistic.
  8. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    I don't think it is possible to cool Volt battery pack with air. It has to provide 150 hp to propel the SUV weight compact car. It has to work so hard because the gas engine was not design to assist/blend.
    Why? GM wanted to call it an electric car and avoid calling it a hybrid. Yes, it is just semantic but they thought it is a huge bragging right for marketing reasons. The engineers added a lot of complexity to realize it.
  9. oldasdust
    oldasdust Member
    356
    47
    illinois
    Thanks USBSEAWOLF2000 that explains the battery cooling and i did not realize the big weight of the volt. Looks like sometimes things get so complex from an engineering standpoint problems are caused them the media takes off with it like toyota faced with acceleration and brakes on the Prius. Wait till the pip comes out any little glitch and the press will be all over it, but the smart members on Prius chat will short out the truth like always. That you all for the great and smart input.
  10. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    Basically engineering problems were created and then solved when they could have been avoided by simplifying.
    Another example is the gasoline going stale from not using it.
  11. evfinder
    evfinder Member
    293
    72
    Apparently the NHTSB has been able to duplicate the problem. It occurs when the battery pack has been compromised at the same time as the coolant line gets cut and there is significant charge in the batteries. The protocol for dealing with the Volts batteries when they have been compromised will the to drain the pack. It has been likened to draining the fuel tank on a car when it has been ruptured in a crash,
  12. evfinder
    evfinder Member
    293
    72
    Forgot to mention that there also needs to be a significant time elapsed after the crash (In the original case it was 3 weeks).
  13. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I think GM might have come out ahead if they had just swallowed their pride and basically copied the regular Prius. Just a matter of time and Prius will be copied nearly verbatim (Insight does not count). Hopefully they can stay on course with Volt.
  14. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The PiP uses a blended electric/gas design because it has to given its small battery size.
    There is a market for customers that don't want the gas engine revving up while they have battery charge available. This is why GM markets the Volt as EREV and will also market a Cruze as a blended plugin hybrid like a PiP but with a larger battery pack.
    I personally want the engine to shut up and not burn gasoline unless I'm driving on a longer trip when I must burn gas because of range limitations. I want an EV experience with long range without paying $30,000+ just for the larger battery pack itself. That's the design center for the Volt and that's what I want. When 300+ mile battery packs drop under $10,000 with 45 minute quick charging then I'll ditch the gasoline engine and go EV-only.
  15. oldasdust
    oldasdust Member
    356
    47
    illinois
    Jeff N That is what most people are waiting for and which company is first ,will have people in line for miles, wanting one or two.
  16. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    300 mile packs with 45 minute charging? I'm sure as long as you have access to your own power plant, should not be a problem. for the rest of us, using some common assumptions:
    300 mile range @ 250 Watt hours/mile, equates to a 75KWH battery pack (in fact this is about the size Tesla is using in the Model S 300 mile pack), charging that in 45 minutes would require over 100KW of power delivered to it, after loss's, your not likely to find that many places, and if you do, there will be heavy demand charges, especially in California. Not to mention the tremendous heat from charging that pack... basiclly we can't do it with current technology.
    Even the Nissan 50KW DC fast chargers, which they are GIVING away 400 of them in Europe, would not find homes in the US, because of the heavy demand charges.
    I think you will be waiting a long long time (reality: forever), for that. We don't and won't need 300 mile packs, if DC fast charging infrastructure is deployed as well, more like 100 miles (24-30KW packs) would be plenty, with 20 minute stops to recharge it.
  17. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I was implicitly using the Model S with the 300 mile battery pack as my example.
    I'd be happy with a Model S except that it's a little too large for my garage and it costs $77K+ before rebates and credits. Tesla claims they will be installing 90 kW fast chargers along major interstate highways so apparently it really is possible.
    The LEAF and it's 24 kWh pack is nice but I personally think it is impractical for the longer driving that I sometimes want to do and I'm willing to pay a few thousand extra for a car that doesn't require me to get a rental when I want to go on a longer trip. I did a fast charge on a rental LEAF recently in Portland during a business trip and it took around 45 minutes at a starting power of 35 kW. Then add in the overhead of exiting and re-entering the highway, waiting for another car to finish charging before you can start, not being able to use all of your battery capacity between charging because of the limited geographic availability of fast charging stations, etc....
    I don't want to drive an hour, charge an hour, drive an hour, .... I would be happy to drive four hours, charge an hour, and drive four hours since that is a closer match to my inherent biological needs to eat, excrete, and stretch my legs.
    Counterintuitively, a larger battery pack would also save me the $1-2K expense and hassle of buying and installing a 240V EVSE. With the larger range, I could just charge on 120V adding 25-35 miles of charge every night which would match my long-term average driving needs even if I drove a couple of 100 mile trips on back-to-back days. On the rare exception where I would run short I could just do a local fast charge or fill the gap with some 240V opportunity charging at local businesses.
    Maybe a 300 mile range will be possible in a $10,000 battery pack in 10 years when I'm ready to give up my Volt. If not, I'll probably buy another EREV.
  18. mitch672
    1,077
    197
    Randolph, MA
    If there where even %25 as many DC fast chargers as gas stations, and they could charge your 25-50KW pack in 15-20 minutes, that would be "good enough" for most people. We may never get to the point of battery equivalency to gasoline, and frankly it isn't needed to have widespread EV adoption.
  19. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    Like Google copying the iPhone...
    (I love my iPhone and Prius and looked forward to my PiP)
  20. BadBeans
    BadBeans New Member
    Seattle
    Seems to me the volt fire issues aren't greater than conventional fires in gasoline vehicles. Afterall the fire doesn't occurr until well after the collision and the passengers would likely already be removed.
    As far as my prefect vehicle. It would be a car like the PIP, except with about 100 mile battery and an engine that doesn't start until the battery is depleted, then turning into a 50mpg hybrid. That would cover my day to day needs with a single charging at night, plus I'd have gas engine range with great fuel economy. I'd also likely use a tank of gas a month and avoid stale gasoline. Of course I'd like it less then $30k.
