Volt gas tank is 9.3 gallons
Discussion in 'Chevrolet Volt' started by TonyPSchaefer, Oct 1, 2010.
  1. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I just stumbled on this piece at GM-Volt.com:
    Breaking: Chevrolet Volt Gas Tank is 9.3 Gallons
  2. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    We should all hope the 300 mile CS range mantra pre-dated going to this size tank, because at 32 mpg CS mode few buyers would find it attractive: those needed CS mode will benefit from PHV Prius, while those not using CS mode will benefit from Leaf.
  3. Autosavant
    Autosavant New Member
    Philadelphia Area
    The EPA says that it will travel 344 miles on charge-sustaining mode, so I think they're set from that standpoint.
  4. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    Another good part is...
    "We need to realize this information is not as important as we think though. The Volt is really about the total car experience and the fact that the majority of driving will be done on electricity alone."
    Perfect sentence, then why having an ICE after all? It's a minority of driving...
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Recently i have spoken to some of my neighbors about the changing
    car purchasing landscape of hybrids (I include the Volt in this category)
    and relatively soon to arrive EVs. These folks aren't concerned about
    MPGs calculated to the tenth of a mile. Their concerns are much more
    fundamental.
    There is a general concern about the finality of an EV's range, you just
    can't quickly "gas up" and therefore escape the consequences of your
    failure to plan or simple lack of awareness. The idea of the Volt's "get
    home" ability is the car's saving grace in their minds.
    Successful EV use will require a fundamental change in the way drivers
    think about personal transportation. Our whole transportation system
    has been designed, or evolved, so that people don't really have to think
    about what they really need, or what they are doing:
    Cars are generally over powered.
    Cars are generally bigger than needed for typical use.
    There are gas stations virtually everywhere. You don't have to plan
    ahead, you don't really have to consider efficiency, either of the car
    itself, or how you use it.
    Vehicles like the Volt and the PHEV Prius at least give potential EV
    buyers/users the chance to think about them with one foot resting on
    the unthinking, safe ground of falling back on the known, comfortable,
    virtually fail-safe, ICE support.
    IMO, this is a small step in the right direction.
    3 people like this.
  6. fuzzy1
    10,254
    This must be part of the reason I have a difficult time comprehending some of the Volt criticisms. Having a route with a triple-digit stretch without open fuel stations, I've never been in the don't-plan-ahead mode.
