Voltage sensor wires repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by macman7500, Mar 14, 2025.
  1. macman7500
    macman7500 New Member
    Los angeles
    Hello, I'm wondering what is the best way to repair or replace this one sensor wire on the busbar. It is almost broken.
    I have another harness but two tabs is broken as well. Can I transfer one single wire from it?
    Also how to avoid this problem? I'm thinking I put some silicone grease behind the nut to prevent the tab from spinning.
  2. Tombukt2
    Tombukt2 Senior Member
    12,993
    2,329
    Durham NC
    Hold with needle nose knipex pliers whilst turning nut off . . You'll be applying new
  3. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Don't waste your time trying to repair, it almost results in a redo.
    Either get a new OEM No.2 Frame wire from the cheapest online Toyota dealer (not eBay or Amazon) or an aftermarket from ACENBAY. Both are good options.
    You don't really want to be opening up the hybrid vehicle (HV) battery more than you need to.
  4. macman7500
    Los angeles
    Yes, I will try this thanks
    I already bought this replacement wire harness but it is used. Don't want to buy it again, but I will next time
    #4 macman7500, Mar 15, 2025
  5. dolj
    dolj Senior Member
    8,450
    4,291
    Used can work too as long as it is in good condition and not full of corrosion.
