Volume level erratically changing by its self
Discussion in 'Gen 2 Prius Audio and Electronics' started by Prius77094, Jul 23, 2008.
  1. Prius77094
    Prius77094 New Member
    32
    Houston, Texas
    I came out of a grocery store, got into my 08' Prius, started to drive through the parking lot, and suddenly the radio started changing the volume by its self. I mean it was showing the volume drop down banner (I always keep the MFD on the consumption display) and the volume went down, with the numbers changing erratically. After 10 seconds or so, the banner would drop down again and change the volume erratically again. It has blasted me with high volume, yet. Could that be the ASL? Does ASL actually show you that it is changing the volume? I was not speeding, maybe going 5-10 miles per hour. I have also noticed a few times now, that the audio seems to come on by its self! I'm driving down the road with the audio turned down or off (I'm not sure if the audio was actually turned off, but it was definitely down) and suddenly I'm hearing the radio! Could the ASL be affecting the audio controls? Any help would be appreciated, as I want to shake out the kinks and get my facts straight before I take it to the dealership for no reason.
  2. WWJD08
    WWJD08 New Member
    70
    Frederick, Colorado
    The dealership says my ASL is working but I can not tell, I always have to turn it louder.
  3. davidtm
    davidtm Member
    180
    TJ'ville
    I never see when the ASL is working, and your description of that behavior sounds very abnormal in my experience. I suggest having the dealer take a look.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    ASL does not show the volume banner on the MFD. Pressing either volume button on the steering wheel does. If you weren't pressing a button on the wheel, the MFD, or turning the volume knob on the radio, then it's time for a trip to the dealer.
    Tom
  5. pkittie
    pkittie Junior Member
    50
    LaLa Land
    I find that if I turn the wheel erratically or suddenly (usually when someone pulls out in front of me quickly without warning), the palm of my hand will hit "mode" or "volume". It's a very subtle how my hand hits it. It took me a while to figure that out.
    When I was driving a friend's car (Mazda), it was happening all the time and I couldn't figure out until the BF observed me.
  6. Prius77094
    32
    Houston, Texas
    Thanks for the replies. I ruled out my hand hitting the steering wheel controls because I actually came to a stop and watched to see if it happened again, and it did. I hope the dealer can reproduce the problem, since it happens sporadically. I'll keep an eye on it and report back here. Thanks, Bill J.
  7. Jennjay
    Jennjay Member
    142
    Fort Myers, FL
    I had the same problem on my '06 that I traded a few months ago. It happened sporadically and had nothing to do with the steering wheel controls. The volume would just come up on the MFD and lower and raise itself. The dealer was never able to reproduce the problem. Have not had any problems like this with my '08 and hopefully will not in the future.
  8. echase
    echase New Member
    227
    I suggest liberal application of the "technical tap" to the buttons on the wheel and the volume dial. A few good strong thumps with the index finger should do it.
    If it's going up AND down, I suspect the volume knob (not buttons) is to blame, if the thump doesn't do it it's time for warranty service. Good luck reproducing it at the dealership!
  9. echase
    echase New Member
    227
    Oh, and if you don't think your ASL is working just turn it to "high" to get a stronger effect.
  10. Joekc
    Joekc Member
    265
    16
    This is the second car I've had with ASL and even with the response turned to high, I've never found it very useful. I still have to turn the volume up on the interstate.
  11. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    Most likely you will need to have the radio replaced. The steering wheel controls and wiring are a possibility, but because of the way they are designed it's more likely the volume encoder knob in the radio itself is flakey. Visit the dealer, they will most likely install a new radio no questions asked. Gotta love warranties!
  12. Prius77094
    32
    Houston, Texas
    It did not happen today. I am inclined to agree with the above poster that it may be occurring in the volume control on the radio and not on the steering wheel. I'll keep an eye on the forums here to see if others are encountering the problem. If my little problem continues, I'll use my cell phone to video the event and then show it to the dealership. Hopefully, that will be evidence enough, or maybe not.
  13. DougSlug
    DougSlug Member
    124
    Trenton, NJ
    I have the same problem in my '06. It seems to occur when the temperature is high. In my case, the problem is also accompanied by a problem where the volume knob on the head unit does not respond unless I push it in and out a few times aggressively. When the problem occurs, the volume number flickers back and forth between two adjacent numbers. This is a classic symptom of a faulty rotary encoder, which is the type of component used for the volume knob in a digitally controlled head unit. I assume this is also somehow causing the random "automatic level control" problem you andand I are experiencing, but there may also be something wrong with the steering wheel switches (or the wiring or connections to them). Since this problem has been described by multiple people, I am more likely to go with the faulty rotary encoder component as the cause.
    This should be covered by the warranty. I haven't yet had the chance to take mine in for repair, but I'll post the results of that visit here.
    - Doug
  14. CindyH
    CindyH New Member
    I am having the exact same problem with my 2007 Prius. I can tell you that it is NOT the ASL because I turned it OFF to make sure. AND I am sure it is NOT accidentally touching the steering wheel controls. It sometimes blasts me when I least expect it and scares me to death!! I have thought about taking it to the dealer, but it only does it when it feels like it...so if anyone has any thoughts on how to proceed, it would be great!!
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    have you wiped off your wheel recently? if moisture gets in behind the buttons, they will short-out for a small lengh of time. I've had this happen recently.
    As someone else has listed... your contacts may be wearing... i'm at 100k.. mine are not worn out.
    If i remember correctly, the U.S. versions do not have a functional ASL system... or maybe that was only 04 and 05 units (before the software changes)
    try changing the ASL volume. Set it to 0.. and jump on the freeway.. jump back off.. change it to it's highest setting and jump back onto the freeway. You should notice a change in tone as you gain speed, or accelerate heavily.
  16. watt2003
    watt2003 New Member
    I'm having this problem with my 2006 Prius, and have had it into the dealer 3 times for investigation. Because I can't give them steps that will reproduce the issue 100%, they haven't been able to reproduce it. Toyota has agreed to cover the repairs if they can ever figure out what's wrong, even if the warranty period has ended, but won't just replace the steering wheel controls or stereo.
    Has anyone successfully resolved this issue?
  17. farrellcsun
    farrellcsun Junior Member
    24
    @DougSlug - I have the exact symptoms you describe in your post. Additionally, sometimes when i press and hold down on the fast forward or rewind buttons to "seek" within a CD track, it skips completely to another track. I have an 07 Prius, package 6 with 32k miles. I plan on asking the dealer to check it out at my 35k service, but it seems to be intermittent. I agree, high heat seems to be when i notice it more. It's 100 degrees in LA this past week!
