VSC, ABS (!) and brake light on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alex Young, Dec 9, 2013.
  1. Alex Young
    Alex Young Junior Member
    26
    Perry, Georgia
    Hi all,
    I am an owner of a newly acquired 118k 08 prius. I have driven it about 600 miles and love it. I took it to my local toyota last week to have the recall work done, which included the hybrid electric water pump assembly and a new bolt in the steering system. Anyway, my wife took the car on an out of town trip, probably drove about 200 miles, so we had put about 250 miles total between us and the service, maybe a little more. Well this morning after starting to back down my driveway all the lights mentioned in the title of the post came on. I turned the car off, turned it back on scanned with a regular OBDII tool and no codes and lights were off. Went through a drive thru on the way to work and the lights came back on and stayed on for 15 miles or so to work. Got to work, turned car off, came inside read about the problems on here and took it to my toyota dealer a mile or so away. The lights did not come back on during the short trip over there. What are the odds they find out hte coolant system for inverter still has air in it after the service from last week and that's all it is? I am hopefull as I really don't want to drop any money on the car since I have only had it about a month. I do find the timing interesting though. I probably put 300 miles on it from the time I bought it to the time of the service and not quite that much after the service then all the lights come on. Thanks and looking forward to many years of Q & A on this board!
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The brake system lights indicate a different problem from the water pump replacement. The first thing that I would check would be your brake fluid reservoir. If this is low it can trigger the above lights.
    Any chance you were hitting any slick surfaces and losing traction?
    As for the scanner, a standard scanner will not indicate Prius specific codes. It will take a scanner that has the ability to read the Prius specific codes.
  3. Alex Young
    26
    Perry, Georgia
    Thanks for the reply jdcollin5. I was referencing this thread (search google for VSC, ABS, (i) and emergency brake light on as I can't post active link yet, this is only my second post) when refering to inverter coolant pump and it's affect on even DC voltage that can apparently cause these lights to come on. I am still hopeful that's the case. There was no situation that I hit slick surfaces while the lights came on for me, although it's possible my wife hit some this weekend and not sure if the codes could have been hanging out and causing the light to come back on after short driving period. Also, I have an ABS scanner at home, didn't have it with me in the car, will that read the codes? I am guessing it's all a moot point as I took it over to Toyota and told them I thought there was a chance those lights were coming on because of air in the inverter coolant system, so I am guessing they will be scanning the system as part of a check and I will probably be given the info sometime this morning. I was hoping someone who has gone through this might be able to tell me what their experience was regarding the lights. I find it interesting they are not on all the time and I find it interesting that it took 600 miles to come on. I don't think the Ford Dealer I bought it from used would have been able to hide those codes from me for that long if there was a problem. I hope not!
  4. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Sounds like a problem with the steering recall. Do a search on this site, you may have to go back to the dealer.
  5. jdcollins5
    5,131
    1,342
    Wilmington, NC
    If you can get the DTC codes from the dealer, post them on here and others will be able to decipher and help with an explanation and/or verify the dealer's explanation.
    If it requires you to pay for additional work you may want to get input from others on here before proceeding.
  6. Alex Young
    26
    Perry, Georgia
    Toyota dealer just called back, said there was no air in coolant reservoir, that the car seemed fine and there were some pretty old codes hanging around in the system, so he cleared them all. I will try and get the list of codes when I go pick it up. They said they don't think anything is wrong with the car. I did a search for the steering problem, doesn't seem like that thread indicates it was any of that work. I do find it certainly an odd coincidence. None the less, since they are telling me the codes were all real old and nothing seems, wrong, hopefully having cleared the codes will prevent those lights from coming back on as I work with computers and they do seem to have a mind of their own at times.
  7. Alex Young
    26
    Perry, Georgia
    I just went and picked the car up. They had it sitting ready to go and were pretty busy and didn't give me any paperwork on it out the door. I did sign something when I dropped it off, so I know the visit is recorded. I will just monitor and if the codes come back I will post them up. I may drive it around at lunch today just to take it around town and make sure it doesn't do any funny business. The car had been driven about 6 miles by the tech according to the ODO. The brakes were nice and tight, so not sure what he did, but they were stopping great and didn't take much pressure at all. Thanks for the replies and I will let you know if anything else comes up.
  8. jdcollins5
    5,131
    1,342
    Wilmington, NC
    You can go to ToyotaOwners.com, create a new account, and enter the VIN. Since this work was done by a Toyota dealer the service report should show up online. It may take a few days before it shows up. It will also show any past service work completed by Toyota dealers by previous owner(s). It would be good to review.
    It will typically have a copy of the Service Report which may or may not include any DTC's that they cleared. It may be worth a try.
    dougz4m likes this.
  9. Patrick Wong
    18,200
    6,492
    1. Look at the inverter coolant reservoir when the Prius is READY. You should see fluid turbulence in the reservoir. If not, then the newly installed coolant pump is not working or there is air in the system. You can also listen to the pump located behind the driver's side headlamp. If you hear air bubbling around, that is not good.
    2. The various warning lights mentioned in your title will appear when the inverter coolant pump is not functioning so you offered a reasonable guess. The reason they will appear is that when the inverter overheats, the DC/DC converter will shut down which means the 12V bus voltage will drop, being dependent now on the condition of the 12V battery. The skid control ECU is very sensitive to abnormally low voltage on the 12V bus since the braking system depends upon electrical power, and will light up those three warning lights.
    3. If those warning lights came on, then the skid control ECU should have posted DTC and those should have been retrievable by your dealer tech.
    jdcollins5 likes this.
  10. Alex Young
    26
    Perry, Georgia
    Update:
    So I left work in the rain yesterday and had to slow down a little quicker than I wanted to to make a turn and the ABS kicked in and the skid symbol flashed. It seemed like the system grabbed a little harder than it should have as I have slowed faster than that in other cars with ABS without recalling it kicking in. None the less I drove home 15 plus miles with no issues. I also drove the car about 10 miles at lunch yesterday. I drove the car around just a little while ago for lunch and the lights came back on!!!! So first I bought a scanguage II and no codes (not sure if it works with the ABS codes or not). So I left the car on the whole time, drove back to Toyota and they agreed to look at it again. I will get codes from them today for sure. The check in person swore the codes yesterday were old, not recent, but I left the car running so they could see the brake, ABS, VSC etc on. I hope they left it on until they got a chance to scan. They are going to call me back. I did ask them if they had checked the 12 volt at any point when they did the recall work or the diagnostic yesterday and the person at check in was not sure, hopefully they will check that today. I'll keep you posted, thanks again for all the feedback.
  11. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Good luck. The SGII will not read ABS codes without an XGauge first being configured. It will read standard engine and emission codes but not Prius specific codes such as ABS.
    I have the XGauge configuration parameters for certain Prius codes for my Gen 3 but I do not know that I have seen any configuration for the Gen 2.
  12. Alex Young
    26
    Perry, Georgia
    They read the code and it was C1249 and indicated the majority of the time that comes up it's the brake light switch. I went ahead and told them to order it and put it on since they have diagnosed the car for "free" twice since the recall work last week. It's also gotten cold enough here that I don't want to be jammed under the dash with cold fingers trying to put it in. It's going to cost me $171 parts and labor, which is probably way high, but at least it will be warranted and should the ABS lights come back on hopefully I will get some more assistance from them. When searching the forum this code did seem to have been handled as a brake light switch issue, so hopefully that will be the end and my ABS Computer is not bad.
  13. Patrick Wong
    18,200
    6,492
    Yes, that is a reasonable diagnosis.
  14. Alex Young
    26
    Perry, Georgia
    They replaced the brake lamp switch and noted on the ticket that if the lights came back on I would need a skid control ECU. If the lights come back on and I do in fact need one of those, it will be an ebay unit with my own labor. Hopefully that's not a tough install and doesn't require any special reprogramming.
  15. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    If you replace the skid control ECU you should also reprogram the linear solenoid valve offset. This can be done with a Mini VCI and Techstream available on Ebay for around $30. This is far less than the dealer will charge you for this. You will then have the Equipment to do almost any other service job requiring the dealer equipment to carry out, will read all the DTC codes issued by the Prius,and will clear them.
    John (Britprius)
  16. Alex Young
    26
    Perry, Georgia
    Just a quick update. In my case it appears the brake light switch was the likely culprit. I have driven the car about 500 miles with no lights on dash. If the lights come back on at any point and new repairs are required I will definitely post.
    jdcollins5 and koolingit like this.
