vsc,abs and circle warning lignts on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cdsjklee, Mar 7, 2009.
  1. cdsjklee
    cdsjklee New Member
    nor cal
    Hi
    I have 2007 prius lately vsc,abs and (circle)yellow, 3 warning lights on
    it turns on while I was driving and when I turn off the car and turns back on it usually turns off. but today it turns on and off by it self while i was driving. Does anyone had similar problem anyone know hot to fix it.
  2. Patrick Wong
    18,200
    6,474
    How many miles on the odometer? Have you checked your tire pressure?
    If your tire pressure is correct and the lights still come on, then I suggest that you visit your dealer for diagnosis. This might be a problem with the skid control ECU, or a problem with the inverter cooling pump not working and the 12V bus voltage sagging.
    In any event this should not be ignored as non-functional ABS and VSC constitute a safety issue.
  3. cdsjklee
    cdsjklee New Member
    nor cal
    The circle warning light is not the tire warning light. and when those lights are on car brakes fine. The abs,vsc and the other warning lights comes on and off by itself when car is moving.
  4. Patrick Wong
    18,200
    6,474
    I suppose you are referring to the brake warning light that has an exclamation point inside a circle, with ( ) surrounding the circle. When that light goes on this means that the brake system is impaired.
    Although you say the car "brakes fine", if you had an emergency situation where you needed the ABS or VSC to work and those lights are on, then you would find that those systems would not be available to assist you. I again suggest that you visit your Toyota dealer so that diagnostic codes can be read and a diagnosis developed. Good luck.
  5. cdsjklee
    cdsjklee New Member
    nor cal
    Can those warning lights check with obd II scanner.
  6. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    If it's a problem with the braking system, you will need the Toyota scantool. As a heads up, never ever attempt to bleed the brakes on the Prius yourself, it cannot be done without the scantool
  7. Patrick Wong
    18,200
    6,474
    If you have an OBD-II scanner that is compliant with the Toyota CAN, you could try it and see. It probably won't retrieve codes produced by ECUs other than the engine and hybrid vehicle.
    Since you have brake, ABS and VSC warning lights on, the skid control ECU is the one that is likely producing DTC. The hybrid vehicle ECU may also be producing DTC and if you can obtain those codes, that might give you a hint.
  8. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    Worst case scenario is that the Skid Control ECU has completely given up on computer-controlled braking and you're down to just braking the front wheels, with no assistance, using the hydraulic friction brakes only. Braking performance is seriously impaired in this case.
  9. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    This sounds similar to when my brake light switch needed to be replaced. Here's that thread. Just a guess...
  10. pleax
    pleax New Member
    UK
    Has anyone changed a Skid or ABS ECU on one of these?
    Does anyone know where it is, or if there's any issues putting in another one from another Prius ?
    I might have to change mine ?
  11. atoeli
    atoeli New Member
    Anaheim, CA
    Pleax, did you ever get your issue resolved?
  12. valsor
    valsor Junior Member
    Bellevue WA
    Yes, I have replaced it on my 2nd gen. Lights gone afterwars.
