VSC, ABS, Brake lights are all coming on during drive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BigYing, Sep 4, 2025 at 8:34 AM.
  1. BigYing
    BigYing New Member
    Thursday
    All,
    Has anyone experienced VSC, ABS, and Brake lights all coming on at start up and during drive (like the photo I'm attaching here). To provide some background, my Prius was recently hit by another car on the rear passenger doorside. So the door and the panel around the gas intake are dented and bent. While this isn't hampering with my drive, to a certain point, the lights coming on are certainly putting me at unease. Is this due to an actuator that got bumped loose? So far I have not seen any negative effects. Your advice(s) are appreciated. (i will be taking this into a shop to get OBD readings.
  2. Merkey
    Merkey Active Member
    307
    277
    Birmingham, Michigan
    Sounds like a wheel spin indicator problem.
  3. Brian1954
    Brian1954 Senior Member
    1,961
    773
    South Central PA, USA
    Report what trouble codes are found.
  4. ChapmanF
    17,655
