VSC, ABS ,Brake & (!) lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sean Talley, Aug 21, 2018.
  1. Sean Talley
    Sean Talley Junior Member
    Atlanta
    First time Poster long time reader.
    I blew a tire last week and had to dive 60 mile on the spare on Front drive tire. I know it a NO-No but Jack bent when lowering. Moved tire to rear and replaced with Full size as others after another 60 mile trip. Are drove fine next 2 days then all lights show up next morning.
    I check 12 V battery in Diag. mode 12 v with HID lights off 14 V when everything is on. I pulled all ABS Relays and the lights went off, Drove a few times and all is ok, Next morning Lights back again Any idea on what it could be thanks for the help.
    49,445
    measure the 12v in the morning with everything off. how old is it?
    are all four tires the same, and pressures to spec?
  3. Sean Talley
    Atlanta
    I checked and battery was at 11.5 v this morning. IDK age of battery. Will look into Yellow Top as most suggest.
    All tires are the same brand size and pressure, Light's didn't come on this morning.
  4. Sean Talley
    Atlanta
    All was it happened again this morning, but the Break indicator was showing yesterday afternoon whe I was Cleaning the Car. I check break Fluid "Full" Check Sensor to Reservoir, and Cleaned Connector, I did hear some Scrubbing of Rear Drums which have about 15K miles on them. Will check them when I get home later today.
    Any thoughts?
  5. bisco
    49,445
    hard to say. let's see what happens after you install the new battery. if the lights come back, you'll have to scan the trouble codes.
    ITBland likes this.
  6. ChapmanF
    15,569
    Or, you could have led with the codes, and we could be figuring out the issue already.
    If they are brake codes, they can be "read" in a pinch with a short piece of wire.
    -Chap
  7. Sean Talley
    Atlanta
    Hey Chap can you explain Further, I parked it and I will check once I get back home.
    Thanks and I will post it later once I test.
    Sean
  8. ChapmanF
    15,569
    Well, you take a little piece of wire, find the Tc and CG pins of the diagnostic connector and put the wire between them, turn the car ON, and count blinks of some lights. You group the counted blinks into pairs to get two-digit codes. The ABS, ECB, and skid lights can all blink out codes (and you need to include which one blinked which codes in your notes, because they're on different lists in the manual).
    If you search on some of the terms I just used, you'll find a pile of threads and posts about it, some with pictures.
    -Chap
  9. Sean Talley
    Atlanta
    Hey chap, did the pins got the flashing codes I recorded it on my phone as it kept rolling.
    I was unable to upload the video as it was too long but here is a link to my Dropbox and the video is there.
    Thanks for all the Help I will post it next as it says more than 4 post to add a link.
  10. Sean Talley
    Atlanta
  11. Ryan Harrington
    Ryan Harrington Junior Member
    51
    16
    Louisiana
    I don't know how to read the blinking lights, but this is bringing back nightmares of actuator replacements. Lol
  12. ChapmanF
    15,569
    Dropbox wants me to allow waaay too much of their code on my computer before I can get anything from the link that was posted. But if somebody wants to count out the blinks into two-digit pairs and post 'em here, I'll see what sense I can make of them.
    -Chap
  13. Sean Talley
    Atlanta
    Can anyone help me out here. I would love to get started on fixing ASAP.
  14. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    I don't bother w/ blinking lights b/c its torture to me. Get mini VCI and Techstream software; this will give you dealer level diagnostic capability. Techstream is what the dealers use b/c it is the official software written to read Toyota/Lexus.
    Amazon Prime: order mini VCI, arrive Sept 10. Doesn't matter which one you order from, as they are all the same and likely come from the same one or two producers in China.
    Search for a 32bit Windows laptop (XP, Vista, 7). Ask friends/family, as someone knows someone who is in IT, and this person will likely have such laptops laying around in a corner collecting dust. Mac installation possible; you will have to figure that out. Spare laptop ideal due to the Techstream software being a hacked copy.
    ITBland and Ryan Harrington like this.
  15. exstudent
    2,213
    901
    Torrance, CA
    Yellow Top is a POOR choice, esp if your car has SKS. Why? 38AmpHr (Optima) vs 45AmpHr (Original Equipment w/ SKS Prius).
    Best choice is TruStart (Toyota Dealers), Bosch (PepBoys), Exide, ACDelco (avail Amazon).
    There are PepBoys in Georiga. $152 for the Bosch. $238 for an Optima.
    Car Batteries | Auto Batteries For Trucks & SUV's | Pep Boys
    Consider getting a smart 12V battery charger that has an AGM setting too.
  16. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    Brake warning light code ( ! ) = 4-7
    ABS light code = 4-2
    VSC light code = 4-5
  17. ITBland
    433
    272
    Sean, there may be other codes, the video stops after two cycles, each code is repeated three times then additional codes will show if present. Just watch one light at a time, maybe take two post-it notes to block the lights you are not watching.
  18. Ryan Harrington
    51
    16
    Louisiana
    This is a sound investment. I just happened to have a 32-bit Windows 7 computer in my closet. The cable from Amazon is only 20 something dollars. As others have mentioned in the past, make sure your battery is fully charged when you connect the computer to the car. Otherwise things go screwy and the connection will be interrupted... Or at least that's my experience.
    exstudent and ITBland like this.
  19. VFerdman
    VFerdman Senior Member
    1,152
    1,177
    Western Massachusetts
    You could also go to an auto part store and most of them can read the codes for free for you. If that does not work, getting an inexpensive Bluetooth OBDII dongle from Amazon and a free app for Android is the next easiest thing to do. Mini-VCI/Techstream is way too involved, often does not work properly due to the fact that the cable is pirated as is the software that comes with the cheap Amazon setup. You will also need a dedicated laptop that runs 32 bit windows (because the pirate software is infected with viruses). The dongle I linked to works really well with all the apps that I tried (Torque, Hybrid Assisstant, OBDII Doctor, etc). Torque app will read and clear Prius codes.
    Good luck!
    ITBland likes this.
  20. Ryan Harrington
    51
    16
    Louisiana
    Make sure you look carefully because the part store will likely use a basic reader that won't read ABS codes (my experience at AutoZone.) Also ensure whatever product you choose will have that function. If you intend to do repairs yourself, you may need a functional techstream setup anyway. Chances are, someone you know has a 8-10 year old laptop laying around.
    ITBland likes this.
