VSC, ABS, (!), emergency brake light on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ascensionist, Nov 2, 2020.
  1. ascensionist
    ascensionist Junior Member
    Seattle
    Have a 2008 Prius. I've fixed many problems over the years; however, I'm finally stumped.
    My VSC, ABS, (!) and emergency brake light are on and cannot figure out why. I searched this forum for answers, but have not found a thread that exactly represents my issue.
    My initial thought was starter battery; however, the starter battery I replaced in April 2020. Tested its voltage: nominal voltage of 12.6; 12.1 under load. I went so far as pulling the battery and charging it (so I could ensure that it was 100% charged), and then reinstalling it--made no difference.
    What perplexes me is the vehicle has thrown no codes and runs fine (as far as I can tell): no decrease in functionality; gas mileage normal. One thread I read which described similar symptoms indicated the problem had be found to be the IG1 relay; I changed this just to see it might make a difference; it didn't.
    Thoughts? I am thoroughly stumped (particularly there being no codes to give me a better clue of things to explore.).
    Thank you!
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    How many miles on the vehicle, and which make/model/app are you using to read the OBD2 codes (DTCs) with?
    Generally speaking, if there are warning lights displayed on the dash then there are OBD2 codes stored in the computers (ECUs).
    Raytheeagle and JC91006 like this.
  3. ascensionist
    Seattle
    A bit more than 200K miles. Replaced the hybrid battery this past April.
  4. ascensionist
    Seattle
    This is my code reader:
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,454
    1,502
    NJ-USA
    Usually if there are warning lights on then some module somewhere will have a code.
    Many Prius owners opt for a pirated copy of the OE Techstream scantool software with a miniVCI interface cable from ebay or amazon. Install it on an old windows laptop and you can access all available modules on the car. Most aftermarket scanners or apps don't have the same coverage.
    Side note, have you checked the level in the brake system? Some cars can set no-code warnings if the fluid is low.
  6. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    The image or link doesn't appear for me. For images, just copy (control-C) and then paste directly in the posting (control-V).
    ANCEL AD530 Vehicle OBD2 Scanner Car Code Reader Diagnostic Scan Tool with Enhanced Code Definition and Upgraded Graphing Battery Status
    Has the above scanner worked for you in the past, and which OBD2 codes (DTCs) did it retrieve?
    It could be that the above scanner isn't fully compatible with a toyota hybrid, maybe try a free scan at an auto parts chain or two.
    Raytheeagle likes this.
  7. ascensionist
    Seattle
    Yes, this scanner has worked very well in the past--never had it not read codes.
    I checked the brake fluid--was a bit low (but this within acceptable tolerance; filled it up anyway--no change).
  8. ascensionist
    Seattle
    Scanned again this evening; got two codes: P1121, and P1122. Any thoughts why/how these codes could be related to all these warning lights being illuminated?
  9. ascensionist
    Seattle
  10. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    My opinion, I think these two codes only account for the MIL (aka CEL; aka Check Engine Light); You also have at least one each VSC, ABS and, Brake ECU codes.
