VSC Indicator light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ed harvey, Jun 21, 2014.
  1. ed harvey
    ed harvey New Member
    I recently had to put a clock spring inside the steering wheel. I aligned it and calibrated it, however, after this change, the VSC light keeps coming on. I have disconnected the battery, I have used the paperclip on the obd connector and calibrated, but it keeps coming back on after driving a few miles. The car runs great. Along with the VSC light, the vehicle warning light comes on also. Please if anyone can point me in the right direction, any help would be appreciated. Thanks, Ed
  2. Patrick Wong
    18,200
    6,492
    You need to have the DTC read. One possibility would be for you to use Mini VCI.
  3. danuaze
    danuaze New Member
    France
    Hi there, did you found any solution to your problem since all those years? I got the same today and impossible to find a solution :-(
  4. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    The first step is ...
