VSC on gravel hills
Discussion in 'Gen 2 Prius Technical Discussion' started by thutchins, Nov 19, 2007.
  1. thutchins
    thutchins New Member
    I love my Prius, but... I have a gravel driveway with a steep hill and every car I've ever had slips a bit on the gravel going up the hill. This has never been an issue till now. As soon as my Prius tires slip a bit I loose all momentum, once the VSC kicks in, and it's tough to get going again since I'm stopped and the tires slip even worse. Tried getting up speed to make the run but always slips a bit and I'm done, also tried going slow, no help. Is there any way to turn off the VSC temporarily???
  2. richard schumacher
    7,663
    1,038
    United States
    Take a run at it and glide until you get down to 1 MPH? If that doesn't work you'll have to try different tires.
  3. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    VSC isn't the problem. Traction control is the problem.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Go up your driveway in reverse.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    It's a problem...reverse has worked for some folks, but be prepared for a harsh electrical/burning smell.
    My lake house has a steep gravel hill and usually I get up fine, but the other day I stalled out about 2/3rds up...finally backed down and got a run at it to get up...
    It seems to be better with recent grating...ie. smoother gravel rather than rutted is easier.
    Since I don't frequently drive my prius up the hill at my lake house it's not a major issue...if it were like that at my home I'd bite the bullet and have it paved.
  6. patsparks
    10,664
    567
    Just 2 strips of bricks would do the trick, no need to have all the driveway paved. Could even look good too. Or you could try road base compacted into the gravel.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's the traction control, and yes, it causes problems with gravel. There is a diagnostic mode that turns off traction control, but it's not meant for driving. You can burn out the electric motor without it. What type of tires are you using? The stock Goodyear Integrity tires are not very good in low traction situations. I had a lot of trouble with them on steep gravel roads where we rock climb. Switching to a good Micheline all-season tire has helped. Carry as much speed as possible up the hill, and keep the gas to the floor when traction control kicks in. Pressing down on the gas tells the control system to try a bit harder. You will get a sort of "whomp-whomp-whomp" sound as the tires spin and grab, but it will keep trying, and often that is enough to get you up the hill.
    Tom
  8. thutchins
    I'm using the stock tires (just got the car in July - hate to waste the rubber). I have reversed up it several times with no problems, only happens in forward. It's a lake house and I will have it paved someday but it will be a while.
    Guess I'll just have to do reverse for now :(
    Thanks,
    Tom
  9. priusenvy
    1,765
    Silicon Valley, CA
  10. qbee42
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(priusenvy @ Nov 20 2007, 05:43 PM) [snapback]542162[/snapback]</div>
    Will they affect the accuracy of the speedometer? Will I see any loss in mileage? How about ride and cornering?
    Tom
