VW ID.7 Revealed
Discussion in 'Volkswagen AG Hybrids and EVs' started by drash, Apr 17, 2023.
Tags:
  1. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Tideland Prius likes this.
  2. Tideland Prius
    16,559
    A normal, stylish (slightly boring?), spacious sedan (and soon to be wagon too!)
    Aside from the silly cost cutting measure on the driver’s door (missing power window switches), the rest looks impressive.
    drash likes this.
  3. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    VW didn't put out a lot of information, but here are some stats from other articles:
    length: 195.3 in (4961 mm)
    width: 73.3 in (1862 mm)
    height: 60.6 in (1539 mm)
    wheelbase: 116.8 in (2967 mm)
    So about the same size as the Model S but VW is positioning for price at the Model 3, about mid $50K starting. Slightly smaller than the Toyota Crown but the ID.7 is a lift back.
    Uses a two-stage one-speed gear box to rear wheel drive (at first but AWD maybe later) powertrain. Base model gets an 82 kWh battery (77 kWh net) battery which gives it 382 miles (614 km) range but to get the 700 km you'll need to upgrade to the 91 kWh (86 kWh net) battery. These range estimates are WLTP so EPA is probably closer to 325 miles (523 km) for the small battery and 370 miles (596 km) for the larger one. No estimate yet of 0 - 60 mph or 0 to 100 km/h. Here are some more websites that most of this data came from:
    2025 VW ID.7 Makes 282 HP, Offers 435 Miles of Range in Europe
    VW's ID.7 electric sedan offers a WLTP range of 435 miles | Engadget
    https://motorillustrated.com/volkswagen-unveils-the-id-7-electric-sedan/113867/
    2025 Volkswagen ID.7: Review, Trims, Specs, Price, New Interior Features, Exterior Design, and Specifications | CarBuzz
  4. Tideland Prius
    16,559
    The target is 5.0 secs for the 4Motion AWD. I suspect the RWD will be in the 6.5 sec range.
    drash likes this.
  5. Mendel Leisk
    41,522
    For 0-60?
  6. Tideland Prius
    16,559
    Yes. This is based on preliminary specs released at the 2019 LA Auto Show on the ID Space Vizzion concept (basically the wagon version of the ID.7)
