Waiting on my '13 Wagon to get here
Discussion in 'Prius v Main Forum' started by tbearprius, Mar 9, 2022.
  1. tbearprius
    tbearprius Junior Member
    30
    Atlanta
    2013 Prius v wagon
    Newbie to the Prius family - bought an auction car that should be delivered Friday. It has 139k miles so was going to ask for opinions on maintenance to do. Was thinking the water pumps? Has many records on Carfax but minimal details to know what was done.
  2. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Well, looks like car will need a head gasket. What would the group say about difficulty of diy? I have replaced suspensions, plugs, starters, alternators, etc. but never a HG. Is this something I should try myself?
  3. PriusHead05
    PriusHead05 Member
    304
    87
    The Toyota Owners website sometimes tells you more than the Carfax does. The thing is it will only tell you what has been done at the Toyota dealership, not anywhere else.
    I would start off with an oil change, engine air filter and cabin air filter replacement, and then inspect the suspension, the brakes, and the tires.
    After those things, I would check the record to see if the coolant, the spark plugs, and the transmission fluid have ever been changed. Both coolants are supposed to be changed at 100k. Spark plugs at 120k. I'm not sure about the interval on the transmission fluid.
  4. PriusHead05
    PriusHead05 Member
    304
    87
    I just saw your post about the head gasket. What makes you say it needs a head gasket?
  5. Mendel Leisk
    38,648
    With those miles, and up for sale, the odds do increase some, but yeah, jumping to conclusions?
    See first link in my signature.
    PriusHead05 likes this.
  6. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Nope, when I got it coolant reservoir was empty and lots of white exhaust that smelled like coolant. Went to clean intake last night and after removing the throttle body, the bottom of the intake is filled with chocolate milkshake. Even the back of the throttle body is coated in it.
    Going to drain the oil tonight but pretty sure my initial diagnosis is correct unfortunately.
    vvillovv likes this.
  7. PriusHead05
    PriusHead05 Member
    304
    87
    By the way, welcome tbearprius!
  8. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Thanks. Wish ownership had started off better but my fault for not having the car inspected first.
  9. PriusHead05
    PriusHead05 Member
    304
    87
  10. Mendel Leisk
    38,648
    Try a leak down test, and/or boroscope inspect the combustion chambers.
  11. PriusHead05
    PriusHead05 Member
    304
    87
    Does it run? If it does, how well?
  12. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Haven't really driven it except driveway. Good thing considering the oil. Engine sounds pretty smooth actually, no knocks, etc.
  13. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Unfortunately, I don't own a kit and my compressor is out of commission as well.
  14. Mendel Leisk
    38,648
    Yeah a pro doing it would be most expedient. Boroscope is an easier DIY though.
  15. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    It's at the dealer - blown gasket. Unsure yet if head is warped. No other shop around where I live wanted to mess with the gasket or engine replacement.
  16. vvillovv
    vvillovv Senior Member
    3,607
    1,271
    NY
    @douglasjre since you have way more experience than I do - have any recommendations for a 13 v head gasket inspection / replacement one state up from you?
  17. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Interesting for mine, when I made a Toyota Owner's account, I can see the dealer record where the previous owner brought it in last June with a cylinder 1 misfire. They replaced the coils/plugs - surprised that a head gasket wasn't looked at during that visit.
  18. Mendel Leisk
    38,648
    It's a common story here; guess replacing coils and plugs is low hanging fruit, and a money maker.
    In previous owner's shoes, I would DIY inspect/clean the plugs, and swap cylinder one and four coil, see if it made any difference to the code.
    Still, with 139K, and assuming no previous EGR cleaning, and cylinder one misfire...
  19. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    From the report, 135k miles so not much driving after the plugs.
  20. bisco
    49,380
    i would search high and low for a mech to do an engine swap. it's not a big deal, and dealer is likely to be outrageous
