Walmart 12 quart boxes of Mobil 1 oil reduced to $30
Discussion in 'Gen 3 Prius Main Forum' started by Georgina Rudkus, Jun 18, 2020.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,422
    2,392
    Taylors, SC
    I found it at my local Taylors, SC Walmart stacked in the aisle. All grades are available.
    Prodigyplace likes this.
  2. Prodigyplace
    12,486
    11,730
    Central Virginia
    Mispriced?
  3. Georgina Rudkus
    3,422
    2,392
    Taylors, SC
    No! The price on line is not always the same as in the stores. The best deals are often not advertised.
    Since it has been a slow mover, they are probably discontinuing the 12 quart boxes.
    My friend in Melbourne, Florida called me and stated their SuperTech house brand 0W16 5 quart bottle was yellow tagged for clearance for $11 a bottle. I founded four at the second Walmart that I visited and bought them all.
    #3 Georgina Rudkus, Jun 18, 2020
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    There's just something about a 12qt box that's too inconvenient. I saw some in 5w-30 a month or so ago and put 2 in my cart. Then I realized it wasn't (12) 1 quart bottles, but a large 12 qt bag of oil in a box. Not my style. Too much of a mishap waiting to happen. Back on the stack it went and into the cart went 5 quart jugs.
    Merkey likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,488
    3,882
    OUCH!! $11 a quart? They sell a 5 quart jug for $23.
  6. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    More like $2.50 a quart :D
  7. bettergolf
    bettergolf Active Member
    487
    366
    Sanford NC
    "5 quart bottle was yellow tagged for clearance for $11 a bottle."
    I think that would be $2,20 .quart.....reading is fundamental.
  8. ASRDogman
    7,488
    3,882
    I Miss read it, wasn't super clear.....
    I'll stick with Mobil 1 or Castrol
    Georgina Rudkus likes this.
  9. Georgina Rudkus
    3,422
    2,392
    Taylors, SC
    I saved a few of the empty 5 quart bottles for waste oil. It wouldn't be too hard to fill them from the 12 quart box.
    Bay Stater and ASRDogman like this.
  10. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
  11. softdown
    softdown Junior Member
    43
    Blanca, CO, USA
    Probably just a local store blow out for some reason. If I can buy Mobil 1 at that price I'd fill the shopping cart.
  12. hill
    8,752
    seems like it was only yesterday, that many manufacturers began recommending 0w-20. What's it been, at least a couple years now?
  13. softdown
    43
    Blanca, CO, USA
    People believe the hype but heavier viscosities protect better. Lower viscosities deliver better mpg. ProjectFarm tests lubricants frequently: One video -
  14. softdown
    43
    Blanca, CO, USA
    Unprocessed sour crude lubricated better than conventional motor oil in one test. Sulfur is a good lubricant it seems.
    There is no question that synthetic motor oil is better than conventional motor oils. No question - every test confirms that.
    Heavier oil is better for hard work like towing and hot weather. Lighter oil is better for starting in cold weather and gas mileage.
    If under warranty - by all means use the manufacturer recommended oil. Don't invalidate a warranty when stuff is so valuable!
    Oil and engine experts could go round and round until "the cows come home".
    If you only do one thing - change your motor oil. Engines literally quit after very prolonged periods without an oil change. Oil basically goes bad with enough wear and tear via usage.
  15. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Walmart also has Super Tech full synthetic 0w16 for $7 / Quart. Cheaper to buy Quart of my piss.
    Question: How is big different 0W-20 vs 0W-16 and when it on Prius Engine?
  16. Prodigyplace
    12,486
    11,730
    Central Virginia
    I would not use it on anything older than a Gen 4 Prius. There was a rumor they shipped from the factory with 0W16 but did not require it initially due to supply issues.
    Bay Stater likes this.
