Walmart Coolant
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Oct 22, 2025 at 12:30 PM.
  1. qmanqman
    qmanqman Active Member
    402
    130
    CO
    Is Walmart's red coolant compatible with the Gen 2?
    I've Googled and Googled and have gotten 8 different answers.
    1. OK in the engine but not the inverter.
    2. OK in both
    3. Not OK whatsoever
    on and on
    I've read there are HOAT, POAT, and PHOAT coolants and for the life of me can't figure out what's what.
  2. BiomedO1
    BiomedO1 Senior Member
    3,296
    1,729
    SacTown, Ca
    When in doubt; use the OEM coolant........
    'Ya feeling lucky punk' (Clint Eastwood).......... If you put the wrong stuff in there, that could be a costly mistake. I'm also wondering if what someone tells you on a forum is any better than Google AI???? Clearly there's a lot of confusion out there and how do you know someone isn't just "parroting" something else they've read, that may also be WRONG??? If your confused; I sure other people out here are too.
    Food for Thought.....
  3. Tombukt2
    Tombukt2 Senior Member
    12,794
    2,298
    Durham NC
    The Asian red at Wally is fine I have I've 300K with it in 4 cars .
  4. Mendel Leisk
    41,091
    Toyota doesn't insist you use their coolant, just cautions (in Owner's Manual), that if you use an alternate, it should meet certain criteria (long laundry list of of do's and don't ensues). The best I can say about that list, is that I understood "some" of the words.
    Accordingly, I stick with the Toyota coolant. For gen 2, is it "Long Life Coolant", or has that been updated to "Super Long Life Coolant"? Replacement interval is shorter with the former, IIRC.
  5. Aegean
    Aegean Active Member
    460
    203
    Alexandria VA
    Buy the red coolant from Walmart and use it without much risk. I used OEM coolant in the 19 years I own the Prius but it did not protect better any cooling system parts. In 200k miles, I have replaced 4 water pumps, 2 inverter coolant pumps, 1 three-way valve. What more protection did the OEM provide over aftermarket coolant?
  6. PriusTech
    PriusTech Active Member
    202
    100
    Reno
    The quality / applicability of anything but the original factory fluid is a question that can't be answered, nobody knows for sure if it's as good as factory, but we do know it's more likely that it's not. For the best price buy it from one of the many dealers that sell online, or get a price there and ask your dealer to match it.
