Want recirc to stay on, or keep previous setting
Discussion in 'Gen 2 Prius Main Forum' started by pri-cluck, Nov 8, 2006.
  1. pri-cluck
    pri-cluck Junior Member
    What is great about the recirc versus fresh air mode is that the noxious exhaust from other cars, trucks, busses, etc. remain outside my Prius. Although I will use the fresh air mode when I am in the open road, as soon as I'm behind another car, especially if we're climbing a hill, I NEED recirc to keep the cabin air from becoming toxic. Therefore, most of the time I drive with recirc on, and as often as possible without the A/C running.
    But when I turn off the car it always resets back to fresh air mode. I do a lot of short trips in a row and have to keep pressing my recirc button every time I restart the car. It is annoying. In all other cars I've ever driven this has been a more mechanical activator which remembers its previous setting. It should really remember the setting after the car is turned off. It does that with other controls, for example the windshield defroster/defogger ... if that is on when I turn off the car it is on when i turn it back on. So why not the recirc?
    Is there a remedy? :blink:
  2. Tideland Prius
    16,195
    Hmm...I'm not sure since I don't really pay attention to that.
    I know my bro loves to leave it in recirc cause the amount of time you can actually use fresh air (on the route we usually take) is short so might as well keep it closed.
    I do remember once starting off in recirc mode but I'm not sure. I'll have to play around with the settings or someone else can chime in.
    Welcome to PriusChat!
  3. daniel
    14,487
    1,518
    Spokane, WA
    The entire design of the climate control system is screwey! It will always default to what it's been programmed for. There is no way to over-ride that. You just have to hit the re-circ or fresh-air button, when you want it different than the car's programmed default.
    When you first turn on the A/C it defaults to re-circ, which is usually the right choice, but in cold weather when you turn on the heat it defaults to fresh air, which is usually the wrong choice.
    Furthermore, with the fan off you cannot change the temp setting, and since some air comes through even with the fan off, you often have to turn the fan on in order to change the temp setting, and then turn the fan off again.
    The climate control is probably the only really STUPID thing about the Prius. It's nice that there is so little stupid about this car.
  4. SaintStephen
    SaintStephen New Member
    32
    My F-150's manual told me to keep the vents open while parking to let the truck 'breathe'. Perhaps Toyota decided to make this happen by default?
    ss
  5. pri-cluck
    The way I look at it, now that these cars have computers and interactive display screens, all the default user settings that are under computer control should be available to us, to set as we see fit. Just like on our personal computers. These machines are expensive enough items to allow for this kind of simple personalization. But at the very least, it should remember previous settings from one drive to the next.
    I do agree, as far as cars go, the Prius is pretty cool, and I have few complaints. Just was hoping if someone knew if there was a way of changing the default for this one setting. Kinda like I was able to turn off the annoying back-up beep. I want my recirc on when I start my drive, that's all.
  6. RBW111
    RBW111 New Member
    139
    El Dorado, AR
    Your dealer can change the default to recirc.
  7. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    In the list of settings, I only see two related to recirc:
    - Automatic recirc when the A/C wants to cool the car. Yes/No, default=yes
    - Foot Air Leak: The airflow whenever the car is moving. Yes/No, default=yes
    There wasn't anything to control recirc directly, e.g.
    - Start up in the last mode selected
    I wish the car had a mode similar to Volvo: Revert to fresh air after several minutes.
  8. Tideland Prius
    16,195
    <div class='quotetop'>QUOTE(pri-cluck @ Nov 8 2006, 07:46 PM) [snapback]346045[/snapback]</div>
    Alright, so I did a check today.
    This morning, I parked the car at school with RECIRC selected. When I came back after class, it started up in RECIRC mode. Now, I was in manual mode so "AUTO A/C" was not showing on the IP.
    So it will stay in recirc when you restart if you're in manual mode.
    Hope that helps!
  9. pri-cluck
    Well I tried it a bunch of times today and guess what? It works now for me too. Strange. Sorry to bother you all with this :huh: . I did try something though, I put the climate control on Auto, then Recirc, then turned off Auto. After that it seems to remember the Recirc setting after shutting off the car. There are definitely some quirks to the programming of this system, but all in all the Prius continues to prove that it is a wonderful car. Thanks for all the help.
    BTW, we actually won this car! Our Prius is a Prize. I noticed that some folks pronounce it that way too. :D
  10. richard schumacher
    7,663
    1,040
    United States
    Defrost will usually (always?) change it from recirc to fresh upon starting the car, so try to get into the habit of shutting off defrost before leaving the car, or checking the state of it immediately after starting the car.
  11. pri-cluck
    <div class='quotetop'>QUOTE(richard schumacher @ Nov 10 2006, 11:53 PM) [snapback]347337[/snapback]</div>
    Thanks for pointing it out, that turning on the defroster will automatically switch the recirc to fresh. It's a bit of "over-programming" in action --- since fresh air defrosts faster than recirc'd air they decided to override the recirc setting. Not what I'm used to, but all cars have their quirks.
    I've noticed another strange thing. Sometimes the steering wheel temp controls will cause the air-flow settings to change, from vent to dash to floor, etc. Anyone else see this? It only seems to happen when the display is showing the climate screen. Haven't been able to figure out what triggers this behavior, almost seems random.
  12. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(pri-cluck @ Nov 11 2006, 08:21 AM) [snapback]347456[/snapback]</div>
    That is the way all automatic climate control systems function. The dash vents are used to cool the passenger cabin and the floor vents to heat it. Generally, when the system is in the heat mode, some air is directed to the windshield to keep it clear. When you change the temperature settings, you switch between the cooling and heating modes.
