Want stainless steel transaxle drain and fill plugs?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Jan 15, 2021.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,170
    2,211
    Taylors, SC
    I just received two of these;
    They are very well made with no sharp edges. They are a perfect replacement for the OEM plugs and has a standard 17mm hex.
    They come with thin copper washers nut will fit the OEM aluminum one perfectly.
  2. working1
    working1 Active Member
    121
    111
    Good find. However, copper and aluminum are on opposite ends of the galvanic corrosion scale. May or may not be an issue, but, could be a reason to keep using the aluminum washer.
