Want start after engine swapped !!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mirena, Jul 27, 2015.
  1. Mirena
    Mirena New Member
    denver
    Hello there,'
    I just swapped the engine on 2008 gas engine don't start !..I know battery is not a fully charged but I have used a jump cable from other car. I scanned and there was a code p0010, I have replaced camshaft timing oil control valve assembly the code despaired but the problem remain the same..
    any help greatly appreciated
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Is the engine turning over attempting to start?
    Does large traction battery show a charge on the display?
    Charge the 12V and eliminate the jumper cable setup. Even though the 12v battery is not responsible for actually cranking the engine, it does need to boot up all the computers.
    Did you disconnect the traction battery orange safety plug? One of the common mistakes when engaging the safety plug is forgetting to slide it down after the pivot.
    #2 IMkenNY, Jul 27, 2015
    49,501
    did you align the timing chain correctly?
  4. Mirena
    Mirena New Member
    denver
    Thanks for your advice, traction battery orange safety plug was not locked properly.. I just connected right and the car is starting ..
    Happy-))
    cheers!...
    valde3 and bisco like this.
