Want to break into the center console... tips?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Dngrsone, Jul 17, 2020.
  1. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    I want to break into the center console of my '16 Prius 2 to add some USB data and charging ports. Is there a guide to doing it or a list of gotcha's for a gen 4?
  2. amos
    amos Active Member
    372
    283
    los angeles
    It takes 60 seconds. Just pull out the black plastic that is surrounding the console. Use a flat head screwdriver and gently pull out. Did it in my car when tried to find the source of that buzzing noise. After that little piece comes out.its all easy to disassemble the whole dash. Not like the prior model
    Mambo Dave likes this.
  3. Dngrsone
    189
    It is just that easy:
    Open the center console
    and push a little forward
    Remove the piece, and the rest of the console just pops up and out. There are wires attached for the USB/Aux port and 12v charging port, obviously...
    dbstoo, LSeanS and amos like this.
