Want to Know How Long the OEM Prius C 12 Volt Battery Lasts?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Oldwolf, Apr 22, 2019.
  1. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    I bought the car new in May 2012. The OEM battery failed today April 22, 2019.
    I jumped started the car, took it to the dealer and they installed the Toyota AGM (84 month) battery for $250.
    Dominic Fong and bisco like this.
    49,504
    that's how long it lasted for you. can't beat 7 years, nice price btw.(y)
    ztanos likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    And it means exactly NOTHING except for that.
    The next guy might get more or less; there are a LOT of determining factors.
  4. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    One thing it means is that if your battery is older than mine was, it may be time to get a new one.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    My car is a 2012 that I bought in Jan of 2013. I'm still on the original.
  6. sam spade 2
    7,035
    2,788
    2017 Prius c
    Says the guy who replaced his battery at:
    3 years
    4 years
    5 years
    etc.
    The personal experience of any SINGLE individual is not terribly meaningful to the rest of the world.
  7. Mendel Leisk
    38,733
    Yeah, the reason it's all over the map, is all the different ownership scenarios:
    1. Driven daily for a good distance, almost without fail, for at least (say) 20 miles round trip.
    2. Driven sporadically, often sitting idle for several days.
    3. Always diligent that lights are off and all doors closed.
    4. Once in a while a door has been left ajar, overnight, or the map lights, or the head lights.
    5. Car frequently gets professional interior cleaning, with doors left open for hours. Staff may be using the car radio.
    6. Protracted idling, or sitting with the car in accessory mode, listening to radio.
    8. Car sometimes sits for multiple weeks, say at airport, or just in storage.
    9. Car is used infrequently, but the owner monitors diligently, using multimeter and electronic load tester, and uses modern charger, one capable of being left on indefinitely, pretty much every time the car will be idle for more than a day.
    10. More so with a conventional battery than AGM: battery is occasionally removed from the car, posts cleaned, ditto for cable clamps, and battery levels topped up with distilled water.
  8. bisco
    49,504
    i think more people drain their batteries than remember, or care to admit. it's just such a different paradigm with prius, they figure jump it and you're good to go, no harm, no foul.
  9. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    At 7 years my battery was definitely on the Right Tail of the Normal Distribution curve of failure age! No doubt a small few will get 8 (or more) years from theirs.
  10. bisco
    49,504
    i'm shootin' for 12 :p
    ztanos likes this.
  11. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    Mine gave no perceivable warning of failure (other than age). I parked at the bank after 15 miles of interstate driving, then when I came out it was dead.
  12. bisco
    49,504
    i check mine on a regular basis, so i won't get blindsided. (i hope :cool: )
    ztanos likes this.
  13. Dominic Fong
    Dominic Fong Junior Member
    Portland Oregon
    Thank you very much Bisco for your reply. Question: is your vehicle parked in a garage? I am thinking a garaged vehicle battery lifespan should be longer than one that is not.
  14. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Mine has never been garaged and I just replaced the factory battery. 117k miles/7 years.
    michael.sfo likes this.
  15. sam spade 2
    7,035
    2,788
    2017 Prius c
    The only environmental factor that is hard on batteries is HEAT.
    So that would be an advantage ONLY if the temperature in the garage is significantly less than it is outdoors.
