Want to replace my cosmetically damaged drivers side door exterior...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by a-dogg, May 27, 2015.
  1. a-dogg
    a-dogg Junior Member
    31
    Los Angeles
    I'm not even sure what subforum to post this in, because it's not really a "maintenance" thing. I mean, the door works perfectly. It's just that a parking lot pillar jumped out at me a few months ago and scraped the driver's side door pretty good. When I search for "door panel," that brings up the door facing the car cabin. Is there a term for what I need? And could anyone recommend a cheap place to purchase one? My best guess would be calling around to junkyards. I'm in LA if that matters.
    Thanks so much!!
  2. JC91006
    16,482
    8,399
    It's probably cheaper just buying the entire door, same color and all from a junk yard. Los Angeles has plenty
  3. a-dogg
    31
    Los Angeles
    Interesting. Curious if you have a ballpark guess how much that would be?
  4. JC91006
    16,482
    8,399
    craigslist is your friend, lots of people selling there. It could range from $100 to $500. depending on who's selling. It's usually a complete door at that price.
  5. a-dogg
    31
    Los Angeles
    Craigslist IS my friend! I used to be close with pinterest, too, but she borrowed $20 and never paid me back, the cheat.
  6. Mendel Leisk
    38,718
    Run it by a body shop? One advantage: putting doors on yourself, getting the alignment right, is tricky. With good paint blending technique it will be like new.
    Also, getting someone else's door, the interior mighta been slim-jimmed multiple times, wiring messed up, hard to say. Interior upholstery condition might be iffy.
    Also, that's a lot of steel going in a dumster; bodywork is greener.
    #6 Mendel Leisk, May 27, 2015
    Okinawa likes this.
  7. a-dogg
    31
    Los Angeles
    That's a good call -- no way to know what's going on underneath the outer shell with a used part. Thing is, my door's not even that bad. It's just that the rest of the car is perfect...and I'm anal.
    Maybe I'm blind...or Craigslist isn't as a good a friend as I thought. But I see *maybe* one black door for sale on Craiglist LA...
    #7 a-dogg, May 27, 2015
  8. JC91006
    16,482
    8,399
    it changes daily, if you're not desperate and don't need it right away, there will be plenty posted......from Ventura to San Diego, you will be able to find them.
    but keep in mind, when you do this, the vin number's on the car doors won't match.
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    You don't need an entire door, just a skin. When the body shop is done with it you won't be able to tell the difference from new. IMO, this is not a DIY job unless you own a body shop.
    The left outer door panel was $246.47 and 5.6 hours labor and 2.4 hours for paint at $48/hour. That's $630.47 before tax and part of a larger job.
    If a professional shop with the proper equipment, facilities and expertise is billing 5.6 hours to replace the skin & hang the door how long do you think it will take you to remove a door then hang and align the used door and make the electrical connections?
    Ask the shop what it would cost for a used door.
    Since the rest of the car is perfect a used door won't be. It'll probably have a scratch, a chip, a ding, or the paint won't match. You may be able to save a little bit of money but you won't be happy with the outcome.
    JC91006, Oh nooooooo! A Prius without matching numbers--the resale value will plummet. Just another reason to buy a skin.
    #9 JimN, May 28, 2015
  10. Mendel Leisk
    38,718
    With a door I think the bodyshop will take the inner panels off and hammer it out, then fill and sand. When they can't access the backside they can electroweld little nails onto the outside face, pull out the panel with them, then snap them off and so on.
    The magic is with the paint: they first paint the damaged area, then dilute the paint with clear, extend out, dilute it again, extend further. Starting with a good colour match, coupled with this gradual fadeout, the new paint is undetectable. If done carefully.
    There will always be subtle clues: a bit different texture, the inevitable overspray, but it can be done very well.
  11. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I would go to a bodyshop. Check online for customer ratings. A good shop like the one I use will explain your options. Usually these days it's cheaper to buy the part new and paint it to match. Labour is getting expensive.
    Pearl S has a new rear bumper cover. It was cheaper than fixing the old one. The paint to my eyes is perfect. But I'm blind in the left eye and can't see out of the right. ;)
  12. a-dogg
    31
    Los Angeles
    So I just went to a local bodyshop, got a quote. $1,200!!! For just the outer door panel. Are they smoking crack?!
    I wonder if it's worth going through insurance for this? Or would that risk hurting my rates too much?
    A skin could be a fantastic idea. I assume you mean...like a car wrap? Or do you mean getting a door from a junkyard and just taking the black, metal outside skin...then replacing the one on my door with that? Do you have any recommendations of where to buy?
    EDIT: oh, god...I'm seeing prices in the $1-2k range, even for plain black... Yikes.
    #12 a-dogg, Jul 8, 2015
  13. bisco
    49,470
    try a few more body shoppes.
  14. Mendel Leisk
    38,718
    You want Priuschat members to glean your insurer and policy, and tell you how much your rates would go up?
    Personally, with our insurer, I would file a claim. Deductible (my cost) would be $300. Rates might go up a bit.
  15. orenji
    orenji Senior Member
    5,884
    3,486
    You would get a new skin installed and body shop would install it and paint it. It may be cheaper to have it fixed with out re-skinning the door. If you can make it to O.C., Fountain Valley Body Works in Fountain Valley is one of the best shops in O.C.
  16. JimN
    7,028
    1,116
    South Jersey
    A door skin is the sheet metal panel that is welded to the door frame.
  17. Mendel Leisk
    38,718
    I've never heard the expression "door skin". Our guy always works with what's there. Or replaces the whole door, if it's really stoved in.
  18. orenji
    5,884
    3,486
    Replacing door skins saves the insurance industry tons of money, I would rather have the existing door fixed like they have done for years.
  19. E. Dennis
    E. Dennis Junior Member
    85
    23
    ca
    2016 Tesla Model X
    You'll probably want the original NHTSA sticker (your VIN #) to remain appearing on your original door.
    So, replacing the door skin is the way to go. Contrary to what other posters have mentioned here, replacing the entire door diminishes the resale value of the car, particularly if an "R-DOT" sticker is affixed to your "new" replacement door, or a rogue VIN number sticker appears on your "neighborhood replacement" door, or there's simply no NHTSA sticker on your "new" door.
    Either way, it's a clear sign to astute buyers that the door is NOT original....and they might therefore conclude the auto has been in a crash...perhaps a T-bone, since the entire door has obviously been replaced. Try taking such a car to CarMax, for example. They'll zero in on a sheet metal replacement immediately...
    Your call....if I was holding onto the car and private-party selling it at some point, I'd want all NHTSA stickers present.
    Just my humble opinion....your car is presumably an '11...so I'd repair rather than replace.
    #19 E. Dennis, Jul 12, 2015
  20. orenji
    5,884
    3,486
    Please know that not ALL NEW cars come with vin numbers/NHTSA on all the body panels. There are some manufactures who do not add them to the body panels. Honda is one of them.
