Want to run a relay, can I disconnect this without codes?
Discussion in 'Gen 5 Prius Technical Discussion' started by Nicad, Feb 9, 2024.
  1. Nicad
    Nicad New Member
    23
    ontario, canada
    2023 Prius
    Limited AWD-e
    Hello, I'd like to run a fused relay to power a pair of horns to lessen the load on the wimpy wiring and horn switch..also to increase performance. I was thinking that running a ring terminal to the main connection in the fuse box would make the most sense to run to the + input of the relay.. If I disconnect this or the 12 volt battery temporarily, will I get codes and or CEL??
  2. Dyjital
    Dyjital Member
    84
    Oregon
    2023 Prius
    XLE AWD-e
    Keep it held down when you release the nut.
  3. Nicad
    Nicad New Member
    23
    ontario, canada
    2023 Prius
    Limited AWD-e
    Yes, I was thinking that would solve it. Make a Big father / son project!
    Dyjital likes this.
  4. Dyjital
    Dyjital Member
    84
    Oregon
    2023 Prius
    XLE AWD-e
    Not sure how I should take this...
    I want to go one way but my mind is telling me somebody was more quick-witted than I was.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,974
    4,716
    Texas Hill Country
    No
