Want to tow Prius on dolly behind motorhome...
Discussion in 'Newbie Forum' started by rscaldwell, Jun 12, 2008.
  1. rscaldwell
    rscaldwell New Member
    Dahlonega, GA
    Got the Prius, got the dolly, now I want to hook up the brake/turn lights on Prius so they also work going down the road. My Roadmaster dolly is currently wired to my motorhome with a 4 pin plug, now I want to have the car lights work also. Any ideas?
  2. biggus
    biggus Junior Member
    55
    Dublin Ireland
    I presume the front wheels are clear of the ground !!. Might be no harm to talk to Toyota about extended towing because of brake regen.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    No Problem! No regen on rear wheels.
  4. rscaldwell
    Dahlonega, GA
    Thanks but I'm trying to get the turn signals and brake lights to come on at the same time that they come on for the dolly. My dolly lights work just fine but now I'm trying to get the car's to come on also.
  5. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    Get the schematics and start digging if you're comfortable with electrics. If you aren't better hire somebody who is.
    I'm comfortable with electric poking so I'd just use a voltmeter on the connector pins to figure out how they connect and how to tap them.
    Here's another option: I think I saw a "Red Green" episode where duct tape (of course), rope and pulleys were used for something like this, but with remote driving included :eek: :)
  6. donalmilligan089
    239
    22
    virginia usa
    I bought a wrecked one (2005) and found tha regular tow dollies will not accomadate a prius because of thier wide stance. Had to load it on a trailer
  7. rscaldwell
    Dahlonega, GA
    I've already been towing my 2006 Prius on my Mastertow dolly for over 3000 miles without any issues except that I wanted to avoid putting those 'ugly magnetic lights' on the back of the Prius. I'm sure there is someone out there that can help me make the lights on my Prius work in conjunction with the motorhome and dolly lights.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I've seen the kind of lights that you mount externally on the vehicle being towed before...if it were me I'd use those for the Prius. I'm concerned that on extended drives the small 12v battery might be drained excessively. I know the lights don't use a lot of power, but it might be enough to give you some problems.
