Wanted - G3 Traction Battery Details
Discussion in 'Gen 3 Prius Technical Discussion' started by kc410, Oct 7, 2014.
  1. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    I have a 2010 that is going to need some attention to its traction batt soon.
    For a couple of reasons I'm looking for a junkyard battery:
    1) so I can take my time rebuilding the "other" battery
    2) So there is minimal down time for the vehicle
    & a third reason
    3) To end up with a battery pack made up of newer cells with fewer miles on them.
    From my research:
    The 2010 & 2011 Prius (through Oct 2010) appear to be the same.
    2011 & newer Prius packs (from Nov 2010 to present) appear to be the same.
    Also the Lexus ct200h (introduced in 2011) may use the same pack as the newer Prius.
    I believe all the above traction batt packs utilize the same physical battery modules.
    So, at the worst case, I could swap-out all 28 modules from a newer pack into my OEM battery.
    G9280-47080 is the part/number of my 2010 Prius traction battery.
    So here are a few specific questions:
    Q1) Are all the G3 Prius & Lexus ct200h individual battery modules (28 modules/pack) interchangeable?
    Q2) What is the difference between the early (through Oct 2010) packs & the later (from Nov 2010) packs?
    Q3) How close are the Prius & ct200h packs? Is it more than mounting hardware? & maybe a battery controller?
    Trying to find out my options ahead of time :)
    Thanks
    Kim
  2. JC91006
    16,673
    8,518
    Might be a bit premature to worry about a 2010 battery pack. If you get one and not use it for 5 years, it will just go bad.
  3. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    You're right - I can name a few premature items...
    That block_6 always has the minimum voltage when the traction batt gets below 40% SOC
    The P0A90 pending code that keeps coming back when the traction batt gets to a very low SOC
    The engine that continues to run when the batt is 60% charged & the vehicle is stopped at a traffic light
    ...or else the traction battery may be starting to have problems.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    kc410, u've got a pm
  5. neez
    neez Member
    194
    37
    This one sounds more like you need a new 12v battery.
    How many miles are on your prius out of curiosity, i'm pushing 90k on my 2011. But i'm not worried about having a spare battery as i have another vehicle.
  6. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    P0A90 is "Drive Motor A Performance". That codes points more to an MG or Inverter failure than a battery. Do you have the info code that comes with it or any other codes?
    Do you have a snapshot that would show the 12 volt battery's voltage when codes are thrown? That would help rule out a failing auxiliary battery.
    FYI, this type of diagnostics might be best left to a professional. You'll be pulling the inverter cover off to check connections as you get into it - something most layperson may want to avoid - if not replacing the transaxle.
    Don't mean to scare you, just don't want you to get hurt or make it overly expensive.
    #6 CARspec, Oct 10, 2014
  7. Greg C
    Greg C Junior Member
    30
    Sydney, Australia
    There is an 8 year warranty on the traction battery, at least in Australia but I thought it was world wide. Therefore take it to your Toyota dealer
  8. bisco
    51,154
  9. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    TY :)
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    Have you had the EOE Safety Recall completed that modifies the software that is intended to help prevent failure of the Inverter Power Module ?
    The P0A90 code could be pointing to this Inverter Power Module.
  11. defrankond
    defrankond Member
    217
    23
    North Dakota
    It always amazes me how people self diagnose these codes. These codes need to be checked by a toyota machine as there are many subsets to the main code. Traction battery should not be going bad unless you are pushing 150k plus miles. I agree with one of the previous posters that it is more likely a 12v battery or a MG2/inverter issue. Since the 2010 had a redesigned inverter a recall was performed to the software so it wouldn't prematurely burn out. That part is covered under Toyota's extended warranty until 2025 with unlimited mileage. Do not always assume it is the battery pack. Voltages of the cells will fluctuate under use and unless the pack has been aggressively used and the car climbs a lot of mountains and has always been at a 100% state of charge for extended periods I do not think it would be a battery pack issue
  12. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    While I agree with most of your statements above the battery is never at 100% state of charge. The maximum is about 81%, and this is not held as the system rapidly brings it down to below 80%.
    John (Britprius)
    gdanner likes this.
