Wanted: info on PHEV conversion price and results
Discussion in 'Knowledge Base Articles Discussion' started by eatdrumss, Dec 12, 2009.
  1. eatdrumss
    eatdrumss Junior Member
    57
    cleveland
    2007 Prius...it currently won't start so it needs repairs...i am considering the plugin mod while having it serviced...will you share some info with me...
    is it worth the cost?
    What is the cost?
    What are the results?
    Does it use the current battery and just ad connections?
    Can my mechanic do it, if he is reasonably intelligent?
  2. bikr357
    bikr357 Plugged in Member
    63
    23
    16
    Houston, Texas
    Spend some time searching the threads, there are lots of options. Unless your mechanic is hybrid trained his is likely not and option. While some of the systems are DIY others require factory trained installers. If you don't know what you are doing or are careless you can fry the car or yourself.
  3. Zythryn
    Zythryn Senior Member
    6,258
    4,258
    The results from the PHEV conversion is largely dependant upon your driving habits.
    If you are in a warm area of the country and drive13-17 miles each way to work you will get huge benifits in mpg (say around 100-125).
    If you drive longer distances between charges, not so much.
