Wanted spare wheel,
Discussion in 'Generation 1 Prius Discussion' started by Martin1973, Aug 19, 2022.
  1. Martin1973
    Martin1973 New Member
    Bourne Lincolnshire uk
    2002 Prius
    ----UK----
    I have acquired a 2002 1st generation prius , its missing the spare wheel
    14 inch, anyone got 1 Lincolnshire area if possible
    Or any ideas if anything other wheels fit. 4 stud 14 inch.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
  3. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    You can find complete wheel spec technicals here: Gen 1 Wheel Rims and Tires | PriusChat
    The keys are really just that, yes 14" and the lug pattern is 4x100. The center bore is 54.1 mm and the offset is 45mm. There are plenty of wheels in the world that fit those specs. I run a set of wheels with winter tires (you know, in the winter) that are from a Ford Escort (b/c I also have a Ford Escort and the wheel specs are identical).
    The thing to watch is the lug style, but that's easily solved. I'm not a big wheel guy, so I don't know the technical terms, but the OEM prius wheels take a pass-through lug - as in the lug nuts go through the rim. The Escort lugs are cones and settle into the conical opening in the wheel. It just means that you might have a different lug nut style to store in the trunk w/ your spare. (That's what I do - I have a full sized spare in the trunk of the Prius, but it's an Escort wheel with an appropriate set of lug nuts if needed).
