Warm Air Intake - Icreased Winter MPG - Insight 1
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Hank101, Oct 21, 2012.
  1. Hank101
    Hank101 Member
    108
    SC
    I am a former Insight 1 owner, and a common mod for improving winter MPG was to reroute the air intake to the exhaust manifold and "scavenge" warm air. This would restore most/all of the lost cold-weather-related MPG, if done correctly.
    I am not sure if this would be applicable to our cars, simply sharing an old trick.
    F8L likes this.
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    It could help but you would still suffer losses due to increased tire rolling resistance, longer warmup times, denser air, cold lube etc.. It is a useful mod though and in addition to other small mods you can make a significant difference. :)
    Some folks used to use insulation to help the engine retain heat. I think Efusco used to do this.
  3. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    I think all new vehicles should have that heat recovery sort of system, I remember it on the old carbureted vehicles back from like the 70s and 80s, I'm sure it helped a little bit. Up in these parts where it gets below -30 C in the winter it would help warmup times...
